NO SPARK WARRIOR
This is a discussion on NO SPARK WARRIOR within the ATV/UTV - Yamaha forum, part of the ATV/UTV Forums category; I HAVE A 2001 YAMAHA WARRIOR. I CANT GET ANY SPARK FROM THE PLUG. I HAVE REPLACED THE PLUG. BOOT, ...
Old 10-30-2007, 08:11 PM
Last Online: 11-12-2007 04:10 PM
Exclamation NO SPARK WARRIOR
I HAVE A 2001 YAMAHA WARRIOR. I CANT GET ANY SPARK FROM THE PLUG. I HAVE REPLACED THE PLUG. BOOT, WIRE, COIL. HARNESS, STATOR, CDI BOX, STILL CANT GET ANY SPARK. PLEASE HELP!!!!!
Old 10-30-2007, 08:24 PM
jhendrix's Avatar
Vroom Vroom
Last Online: 10-20-2009 09:38 PM
Default Re: NO SPARK WARRIOR
Don't post so many threads on one subject, people will see it and respond in one thread.
You don't need three.
Old 10-30-2007, 08:39 PM
NOT THE ANSWER I WAS LOOKING FOR, BUT THANKS ANYWAY!!!! SORRY FOR MAKING YOU READ SO MUCH!!! JUST IN CASE YOU DIDNT CHECK THE DATE IM NEW TO THIS.. WASENT SURE HOW THIS WORKED!!!!!!
Old 10-30-2007, 08:48 PM
spartanbiker_117's Avatar
1997 CR125R
Last Online: 11-18-2009 09:53 AM
You might try a new flywheel in case your current one got de-magnetized. Oh yeah, we can hear you fine so you can take caps lock off
Old 11-02-2007, 05:24 PM
HEY YOUR FUNNY, THANKS FOR FLYWHEEL TIP!!!!
Old 06-16-2009, 08:20 PM
Last Online: 06-16-2009 08:20 PM
Default no spark try
Try diconnecting the wires comming from the reverse switch (l/h lower side)and the wire comming from the reverse lever switch (r/h upper) and grounding them to the frame. this will ensure the start cut out relay is working or just put the relay in your hand and fill it actavate as the motor is cranking. if not working then check the above mentioned switches.
Of coarse there may be a chance that you did not disconnect the battery before connecting your CDI. NEVER disconnect your Stator wires with the battery connected it may screw up your CDI, CDI's dont like 12 volts with no resistance to traval.
For other people with simaler problums, Disconnect the Battery then you can check the resistance (ohms) on the Stator, Ignition Coil, But I have not found a way to check the CDI. But don't forget to check the spark plug cap real good, there is a resistor in the cap, unscrew the inside brass piece were the spark plug connects and there is a small resistor and a spring. But if you checked the coil for resistance then you shouldn't have to do this i9f the resistance checked good.
The last thing may be what the other guy said, maybe the flywheel keyway is missed up and Grab the flywheel while you have the stator off and try to rock it back and forth. Hope this helps you guys.you will have to get the resistance for your year of ATV.
Similar Threads for: NO SPARK WARRIOR
Warrior tip tejas ATV/UTV - Yamaha 11 03-20-2009 09:47 PM
NO SPARK WARRIOR PTARNO 4-Stroke Motorcycles - Yamaha 3 06-23-2008 08:19 AM
NO SPARK WARRIOR PTARNO ATV/UTV - General Discussion 1 12-13-2007 11:47 PM
warrior help!!!!!!!!!!!!!!!!!!!! amroberts Member Introductions 3 05-03-2007 11:11 AM
Is the Warrior on the way out? 2fun ATV/UTV - Yamaha 19 04-23-2003 12:56 AM
