Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums > ATV/UTV - Yamaha
Old 05-03-2017, 07:50 AM
gusco's Avatar
Last Online: 05-21-2018 08:05 PM
Default JB Weld (or similar) for case repair??
I picked up a cheap Yamaha Blaster with a title (rare for our area), and I'm planning on flipping it. I got it cheap knowing it was locked up and began tear down yesterday. It seems the wrist pin bearing went out and allowed the piston skirt to contact the crank and broke the piston skirt. Got the head off (may need to be replaced as it does have some deep gouges) and the cylinder (it is surprisingly in decent shape). Once I pulled the bottom end/cases out from the frame I found that something seems to have jammed below the crank and pushed into the cases. There are two cracks below the crank, one on each case half.
So, I began a little research to see if JB welding is an acceptable fix. What do y'all think? Anyone repaired a case this way? Most of the info I'm finding is for fixing cases that have been damaged by the chain. The way I see it, this part of the cases does not bear much load and it's primary function is to seal in the gas and oil mix to keep the crank lubricated. I'd appreciate input from anyone with experience (good or bad) doing a JB weld (or similar) repair on cases.
Old 05-08-2017, 02:00 AM
Law94's Avatar
Last Online: 05-17-2017 03:02 AM
Never had any experience with JB welding works but would like to know if they can do it.
Old 05-08-2017, 12:40 PM
Would never use JB weld on that point of the cases because there is some pressure difference at the crank case chamber while the piston operates up and down to "push" the mixture at high speeds into the combustion chamber.
Proper fix for this is aluminium welding.
Old 05-08-2017, 06:07 PM
Last Online: 05-22-2018 12:45 PM
I have seen it work before on a cracked case. I wouldn't try to patch a hole with it. I would look for a used case before using jb weld. If you do use it, I would do the patch from the inside. The pressure that is built in the crankcase is pretty low.
Old 05-08-2017, 08:18 PM
gusco's Avatar
Thanks for chiming in! The cases have cracks, not holes. I agree that welding is more appropriate, but I'm trying to keep the cost as low as possible while doing a worthwhile repair. As of now I'm waiting for an impact driver since Yamaha thought it was a good idea to put cases together with screws instead of bolts. Once I tear down completely I'll have a better assessment of the damage. I also need to take the cylinder over to a machine shop to measure the bore.
Old 05-12-2017, 08:08 PM
wFo250's Avatar
will fall over
Last Online: Yesterday 03:06 PM
No problem if done right. As said before, I patch from the inside and outside. Lots of carb cleaner to remove any oil residue, and I hit it lightly with a torch and a small bristle wire brush. Had an oil pump gear punch a rogue bolt head through the case. Patched no problem and was a bit of a hole, and split to the mating surface. Working great. Just make sure you disclose the patch to any potential buyer.
Old 05-16-2017, 08:38 AM
gusco's Avatar
I will be having to purchase some cases or part the bike out. I split the cases Saturday night and there were chunks taken out of several areas all around the crank cavity
Old 06-20-2017, 09:21 AM
gusco's Avatar
Update: I got the cases prepped and assembled the motor over the past couple weeks (I only get to work late nights while the kids are asleep and sometimes on my day off, if there's nothing pending around the house). Everything went back together smooth, but the bike has no spark. The coil tested bad as did the cap. I'm going to replace and see if that takes care of it.
Old 06-20-2017, 12:09 PM
Last Online: Today 07:54 PM
JB Weld will not hold up to fuel as it is petroleum based. It will last a little while, but will let go with exposure to fuel.
Old 06-20-2017, 09:28 PM
gusco's Avatar
Replacement cases were purchased
Old 06-21-2017, 08:01 PM
wFo250's Avatar
will fall over
Although relevant and useful info!
Old 06-26-2017, 03:38 PM
gusco's Avatar
Up, running, and ready to sell!
Old 06-29-2017, 07:49 PM
gusco's Avatar
I could use some advice from you guys:
I'm being offered a trade for a 2015 KTM 85 with a 105 kit on it. The bike looks nice and I think could bring in a little more than the quad (maybe it's just because of my limited experience with quads).
Advantage to the Blaster: 0 hrs on piston and crank.
PERCEIVED advantage to KTM: Higher selling price (??)
Similar Threads for: JB Weld (or similar) for case repair??
JB Weld Repair Honda-Dirt-Rider General Discussion 6 03-04-2013 01:51 PM
Kx 500 main bearing case repair newyorkredneck 2-Stroke Dirt Bikes - Kawasaki 2 05-25-2008 05:18 PM
2006 and similar years YZ450F parts yzernie Classified Ads 10 11-01-2007 08:16 AM
Compatible or similar engine Shadow175 4-Stroke Dirt Bikes - Yamaha 2 05-28-2007 08:50 AM
Can you weld the case? Hybrid General Discussion 7 09-15-2004 08:11 PM
