Cant get my Baffle offThis is a discussion on Cant get my Baffle off within the ATV/UTV - Yamaha forum, part of the ATV/UTV Forums category; For some reason I cant get my baffle off.
I took the 3 bolts off that hold the outer ring ... |
| For some reason I cant get my baffle off. I took the 3 bolts off that hold the outer ring on then, I took out the bolt that is under the exaust end peice but cant seem to get the actual baffle off. Can someone help me with this? |
| Only take out the bolt that is under the end piece. Leave the other 3 bolts in place. After you take out the bolt ride your YFZ around for 10-15 minutes. Then grab a pair of needle nose pliars and give it a good pull. Should come out easily after that. Take off your airbox lid too. Make sure you rejet after as well. |
| AS Crunk has said, I have heard that warming up the pipe/silencer works well to help remove it. I just broke mine in with the stocker, and then immediately got the DR D from Woody. Either way, you will definately need to re-jet! |
| Sometimes they can be stubborn. Good advice. |
| Just make to rejet after you get that bad boy out. No matter if you remove the airbox lid or not you really need to rejet. Go to a 165 main, 42 pilot, 4th on stock needle for you mods is my advice. |
| yeah they hard to get out.... i did mine cold with pliers some some muscle and alot of cussin....... if you kind of twist it, it helps. it doesnt sound pretty without it in, i wouldnt take it out if your gonna get a aftermarkte pipe anyway. 04 YZF450 05-YFZ450 (sold) 02 660R |
| So I will have to re-jet by just taking out the baffle? It will only be out for one day when I go to a MX track this weekend. |
| Yes you should rejet. Even with the baffle in you should rejet. YFZs are lean from the factory. If I were you I'd just throw in a 165 main jet and leave the pilot and needle like they are now (stock). |
If you are taking the lid off too, I would recommend the 165 main, but also dropping the clip to the 5th position. Depending on if you have hesitation at the lower throttle positions, you may also want to think about bumping the pilot to a 45. What is your elevation?? |
| what is a baffle | klxrider3214 | 4-Stroke Motorcycles - Kawasaki | 3 | 08-11-2005 11:44 AM |
| removing baffle | Vinny3299 | ATV/UTV - Yamaha | 1 | 07-14-2005 10:57 PM |
| baffle | burstonecr250r | ATV/UTV - Suzuki | 7 | 02-06-2004 10:04 PM |
| Pulled Baffle off 04' Raptor | roadrash | ATV/UTV - Yamaha | 6 | 12-30-2003 05:05 AM |
| how do take off the baffle and jet the the carbuerator | 04'yfz4u | ATV/UTV - Yamaha | 14 | 11-14-2003 04:05 PM |
