Blaster top speed question
This is a discussion on Blaster top speed question within the ATV/UTV - Yamaha forum, part of the ATV/UTV Forums category; You'd have to look at how much slack you have available in your chain. If you can back off the ...
Old 01-17-2005, 12:12 AM
2fun's Avatar
Super Sonic Moderator
Last Online: 03-18-2010 01:02 AM
Default Re: Blaster top speed question
You'd have to look at how much slack you have available in your chain. If you can back off the chain adj a little, you'd probably be able to get away with it. If your chain is fairly tight, and you have no room to back off, you probably would not be able to do it.
My guess (and this is only a guess) is that you would probably be able to do it, but like I said, it depends on whether you can back the tension off or not.
Old 01-17-2005, 07:54 AM
Blaster2678's Avatar
Last Online: 10-21-2006 07:03 PM
Ok thanks!
Old 01-17-2005, 06:22 PM
Clink116's Avatar
I'm going with both
Last Online: 09-23-2009 10:48 PM
The Blaster is really restricted in air flow, the carb is way too small so if you ever wanted to go faster than what you are going now you need to up the size of your carb to at least a 34 to 35 mm.
There was a really good article in the Jan edition of Dirt Wheels that talked alot about it. They gave horse power gains for all the different mods you can do.
My Blaster will get up to 68 with stock gearing and 21 inch rear tires and a little methanol , so it is possible.
Old 01-18-2005, 03:03 AM
2fun's Avatar
Its funny you should mention that because I've got a couple of 34MM PJ carbs sitting in my garage that came off a couple of 250Rs.
Old 01-18-2005, 10:46 PM
Clink116's Avatar
I'm going with both
If they are still in good shape i would be more than happy to take one of them off your hands for a small fee!
Old 01-19-2005, 02:53 AM
2fun's Avatar
Shoot me a PM.
Old 07-16-2008, 10:52 PM
Last Online: 10-23-2008 08:13 AM
well 70 is a real number to reach.stock blasters run around 50.ive bult 27 blasters to date .im currently building a alcohol hill climber.if u wanna reach ur goals and at a decent price deck ur head .010 or more no more then .020 increase ur sprocket to either a 13 or 14 with 21 inch wheels i run 22s on most of mine and regular fuel wont cut it switch to race fuel98 plus i run 118 and use a synthetic 2 stroke oil it works oo so much better in my bikes and it would help to port it out not only the intake thats all the places seem to do u need to to exhuast as well its great the bike can take all the air and fuel in but it has to leave.u should be right around ur goal and then some ull have more power then 90 percent of the bikes on the trail . most of this work u cold do if ur not scared but be prepared to do tunning to the carb which i normaly run 35mm or bigger and if u or they port too much then ur going to need to change the timing and buy a ricky stator plate. blasters are a great bike that are very reasonable but it takes a lill work for them to shin over the the other bikes .the joe t
Old 07-16-2008, 10:55 PM
Moto Re: Blaster top speed question
Originally Posted by 2fun View Post
Shoot me a PM.
if he dont come through wit the carbs ive got new and used 34 and 35 mm with big and small
entering holes.they came in diff sizes for diff bikes and for diff types of riding . the joe t btdjoe@aol
Old 07-29-2008, 03:30 PM
Clink116's Avatar
I'm going with both
So tell me if you can, what size of pilot jet and main jet do you run with your blasters on gas with a 35 mm carb?
Old 08-01-2008, 08:47 PM
weld_13's Avatar
headline here
Last Online: 08-04-2009 02:08 PM
Now first reall quick, on your tires you have an off brand 18", if your going to be riding a lot of trails your going to want 20"s and if your doing mx your going to want 18"s. Before you start spending money on a chain and sprockets get stuff in line first.
Similar Threads for: Blaster top speed question
another blaster question Blaster2678 ATV/UTV - Yamaha 30 04-20-2005 10:13 AM
Mojave and Blaster question please help! Mojave27 ATV/UTV - General Discussion 5 10-18-2004 10:40 PM
Blaster shocks question TRXman86 ATV/UTV - Yamaha 13 03-03-2004 01:15 AM
Blaster Question Punisher ATV/UTV - Yamaha 33 12-09-2003 11:14 AM
