BLASTER PROBLEMS (WON"T RUN)This is a discussion on BLASTER PROBLEMS (WON"T RUN) within the ATV/UTV - Yamaha forum, part of the ATV/UTV Forums category; I have a 03 Blaster. I put a new CDI Box, Coil, FMF Exhaust with Core 2 silencer, 28mm Keihin ... |
| I have a 03 Blaster. I put a new CDI Box, Coil, FMF Exhaust with Core 2 silencer, 28mm Keihin Carb (#230 main jet, also tried a #135), Spark Plug, K & N Filter, and Stator. I bought it without it running, it didn't have a carb with it. I had the compression tested and its 120-125psi. I kick it about 25 times and then I get a really big back fire with flames out the exhaust. About the 35th kick it will run for about 10secs and die right away. It needs the choke to start. I have been trying new thing for about 2 months and nothing. Has anyone heard of this problem? Please help!!! Thanks John |
The compression you quoted sounds a bit low to me?? |
| yes stock is a 26mm, but I ran out of money. I thought that stock jetting was #230 main and #32.5 pilot, but I could be wrong. The carb I have is close to that, and its is also new. I was told that the compression is good. Thanks |
I was suggesting to go with stock size and stock jetting with the original carb. You have also thrown in other variables such as the aftermarket pipe and silencer. When I had my Blaster with aftermarket pipe and silencer, I was running a 290-310 (I believe) main jet. The needle position and pilot will ALSO have to be changed to compensate for this. Thats why I was suggesting you go back to stock with everything (carb, jets, airfilter, pipe, etc), get it running properly, and then move forward from there with mods one at a time (jetting for each mod as you go) |
Do you know what jetting I should have in the Keihin carb, I would put it back to stock but I got it without a carb and air filter. I don't have the money to buy another new(stock carb and filter). |
Well, I am unsure of the Keihin jet that would match up with a Mikuni. There may be some kind of conversion chart SOMEWHERE on the I-net, but i don't know where it is right off hand. My GUESS and its only a GUESS is that you would want a slightly larger than stock pilot for that carb, try the needle on the middle position, and a 160 main jet. Again, this is just a GUESS. Be sure to do a few plug check with these jetting settings though. You don't want to burn up your motor! |
| When I put my pipe and silencern, I ran a 290 main, stock needle position, and stock pilot. I had a UNI filter and ran 6 vents in the lid. Try to run a size larger main, raise the pilot one size also. I will look up the gap, but you can call a dealer for any ATV shop and they can tell ya. You may double check all your wires also. Maybe one is loose around your coil or stator. |
I have the needle in the middle postion and I am using a #235main and a #45.5 pilot |
Thanks |
| Gap for the plug is .028 type is NGKB8ES. |
| K, I will try that. Thanks |
| To be honest, I am not sure how the pilot size increases. I say just use trial and error. Take notes of EVERYTHING you do. That way if what you come out with is worse, you know where to start again. Go one step at a time. Almost forgot, when you oiled your filter, how much did you use? To much on it will make it suck thru the carb and plug the jets. I know from bad experiance Also, do a search here on the boards for blasters. There have been many questions asked. You may also find even more stuff to help out. |
I didn't oil my filter, it was pre-oiled I guess. SPECS: PWK 28MM 29S, Main -#135, Slow Jet -#38 ,Jet Needle -46JJH Thr Valve- C.A. 3.5 |
Keihins and Mikunis do NOT use the same numbering sytem for jets!! Try to go with the set up I last mentioned. Last edited by 2fun; 12-20-2007 at 04:44 PM. |
Thanks Last edited by 2fun; 12-20-2007 at 04:43 PM. |
| I just tried a #165 and still nothing, it doesn't even want to back fire anymore. |
The needle is approx 1/4 to 3/4 throttle. The pilot jet is for off idle to 1/4 throttle. Take a look in the Knowledge base forums for jetting info. There is a lot of good info there! Like I said as far as carb adj for the blaster on the Keihin, I am only guessing. You are not only using a different carb, but also one that is bigger than stock! Do you have spark?? |
#18
#19
At least you'd have a ballpark idea in which to start. |
#20
| PS, I could be wrong, but that compression still sounds a bit low. I know the stock compression on the Banshee is about 120-130 on each cylinder, and they run at a lower compression than the Blaster does. I've been trying to research it, but I get varying results, not to mention that compression gauges (most anyways) do not usually give a correct reading. The one I had was off by about 20 PSI, and my friends was off even further. Just something to keep in the back of your mind. |
| blaster mix and match problems! | blaster1988 | ATV/UTV - Yamaha | 2 | 04-23-2009 06:16 AM |
| 2005 blaster problems | 2smoker85 | General Discussion | 3 | 01-11-2009 09:05 PM |
| Blaster Problems (won't run) | johncam25 | 2-Stroke Motorcycles - Yamaha | 3 | 12-30-2007 09:42 PM |
| "Power band problems" | Shoei_391 | General Discussion | 21 | 11-10-2007 07:16 PM |
| Help! blaster problems | Billyboypaints | ATV/UTV - Yamaha | 7 | 07-14-2007 06:14 PM |
