Go Back   All Things Moto! Dirtbike Forums > Dirt Bike - ATV - Suspension Forums > ATV/UTV Forums > ATV/UTV - Yamaha
Old 05-18-2012, 03:12 AM
Last Online: 05-18-2012 03:26 AM
Default BIG BEAR 350 1995 gear shift issue
Hi Chaps
On the above vehicle...both side cases were leaking oil so I took them both off and replaced the the damn thing won't go in into gear/ seems to go through the gears when it's not running, but once I start the engine the shifter seems to lock up
REALLY appreciate some help
Old 05-18-2012, 12:28 PM
RiV RiV is offline
Last Online: 10-10-2017 08:21 AM
You will most likely find the problem in the clutch side, there is a three
ball ramp and spring setup stacked on the end of the clutch. If that is
out of place the clutch wont engage properly to unload the trans for
smooth shifting, it would be of great advantage to have a proper service
manual or at least a parts diagram. You may have to adjust the clutch
when you are done as well.....doubt if that would help at this point though.
You almost have to roll the quad up on its side on 2 wheels to get the
parts positioned and to stay when installing the cover. Good luck!
Old 03-08-2013, 07:01 AM
Last Online: 03-08-2013 07:13 AM
I have a 91 big bear and it has the same problem. I really think its the adjustment. btw what is the adjustment on the clutch. (how many turns and witch way) thanks
Similar Threads for: BIG BEAR 350 1995 gear shift issue
97 xr70r shift shaft issue Gear 4-Stroke Dirt Bikes - Honda 1 03-12-2012 02:35 PM
87 Yamaha Big Bear 350 issue jcweso ATV/UTV - Yamaha 9 10-10-2011 04:53 PM
'04 CR250 Shift Issue jeremywatco 2-Stroke Dirt Bikes - Honda 6 10-05-2011 02:41 PM
Gear Shift Oil Leak mxrider21 2-Stroke Dirt Bikes - Yamaha 6 10-16-2008 01:20 PM
shift gear is horriable!! Mr.Boof General Discussion 14 10-19-2004 03:10 PM
