93 350 Warrior No Fire?? Help
This is a discussion on 93 350 Warrior No Fire?? Help within the ATV/UTV - Yamaha forum, part of the ATV/UTV Forums category; Hey everyone!! I'm a newbee here but it looks like an awesome site! I have a problem and i'm hoping ...
Old 09-10-2007, 12:05 PM
Last Online: 11-16-2007 07:50 PM
Default 93 350 Warrior No Fire?? Help
Hey everyone!! I'm a newbee here but it looks like an awesome site! I have a problem and i'm hoping somebody can help! I was driving My wheeler the other day and i climbed a steep hill in the gravel pit. Jumped over the top and when i landed it died. I towed it home with my sons KX80(that was cute lol). Got it home and started checking i had absolutly no fire checked wires can't find anything obvious wrong. switched coils cause thats what everyone says was the prob. but didn't help. any body got any ideas??? any and all help is appreciated!!!! Thanks!
Old 09-10-2007, 04:27 PM
Last Online: 11-25-2007 06:48 AM
Default Re: 93 350 Warrior No Fire?? Help
Got gas? Just bought a 93 warrior have not had that problem yet, I am taking it out sunday though.
Old 09-10-2007, 04:28 PM
Also change the spark plug, I meant to put that with my first post.
Old 09-10-2007, 05:31 PM
Moto Re: 93 350 Warrior No Fire?? Help
For starters...Im not stupid! and second...you dont need gas to have fire! Good luck with your wheeler
Old 09-10-2007, 05:51 PM
no you don't, but gas helps to get it going...Did you hit the red switch by chance...? Do you have it in neutral>? Just asking, yeah it's happened before for got to put it into neutral...lol ...I didn't say you were stupid just trying the obvious...
Old 09-10-2007, 06:42 PM
yzernie's Avatar
Moto Geezer
Last Online: Today 12:23 AM
I'm assuming the engine turns over. I would say that when it happened by landing after getting some air something got disconnected or knocked loose. When you checked the wiring did you remove the tank and check all the electrical connections?
Old 09-10-2007, 06:47 PM
yzernie's Avatar
Moto Geezer
True, but has nothing to do with no spark.
It would not even turn over if the red switch was in the off position.
Has nothing to do with no spark.
Old 09-10-2007, 08:36 PM
swampgrass's Avatar
its all about the girls
Last Online: 03-15-2009 10:26 AM
Yamahas are bad about the pick up coil going bad look on the left side of the motor gear shift side and there should be a green and red wire coming out of it maybe striped wire anyways thats most likely the problem
check it with an ohm meter it should be around 150 or higher if it reads like 25 m ohms or 2.5 thats what it is send a pic. of the wires coming out and i can help you
unless something came loose in the key switch sometimes that happens
hope this helps
Old 09-11-2007, 12:27 PM
thanks for the help guys i will check the pick up coil i really hope thats the prob. I got all the plastics and tank off can't find any bad connections. the problem is b4 i got it someone re wired it all so it doesn't even have the red switch. no kill switch either just the key. but it has worked fine since i have had it in early spring till just the other day. i just hope its not the CDI. and thanks for stating the obvious too some people wouldn't check that stuff i guess. i'll let you know how it turns out!
Old 09-11-2007, 03:17 PM
swampgrass's Avatar
its sounds like the pickup coil to me the cdi boxes only go out when you take them to the dealership if u no what i mean
Old 09-11-2007, 04:27 PM
Sweet Thanks Man! hopefully thats the prob!!
Old 09-12-2007, 01:18 AM
2fun's Avatar
Super Sonic Moderator
Last Online: Today 01:02 AM
Sounds like these guys are giving you a hand. Just wanted to say welcome to
Old 09-12-2007, 08:24 PM
swampgrass's Avatar
if it is the problem when you go to fix it turn the bike on its side so you dont loose any oil plus it makes it easier to work on it
Old 09-24-2007, 12:16 PM
ok everyone finally another day off, and i can look at the bike. i tested the pickup coil and it reads like 460 OHMs i tested a new one and it was almost the same. so i assume thats not the problem. But when i went to test the sorce coil it has no reading at all. i checked the wires going to it and there fine. so i'm thinking there should be a reading there of some sort or atleast a circuit between the two wires. am i correct? do u think this is the prob?
Old 09-24-2007, 08:18 PM
swampgrass's Avatar
yes you are right thats why you check it in ohms 460 sounds like alot to me i wish i had a manual because i didnt think it was that much any ways
source coil sounds like the problem. alright keep me posted
Old 09-26-2007, 07:36 PM
Last Online: 09-26-2007 07:53 PM
source coil should read 270 to 330 ohms.
Old 12-15-2007, 12:25 PM
Last Online: 12-15-2007 12:25 PM
what color is the wire coming out of the engine? im having the same problem. i just wanna start at the source and work my way out.
Old 03-16-2008, 08:12 AM
roostertail6's Avatar
Last Online: 03-02-2010 05:40 AM
Sounds like what plagued me at one time. Take a good look at reverse lever switch wiring.Good luck,
Similar Threads for: 93 350 Warrior No Fire?? Help
Mis-fire / back-fire, wont kick start donzi1971 2-Stroke Motorcycles - Honda 1 11-16-2008 02:46 PM
94 yamaha warrior no fire dillmonty ATV/UTV - Yamaha 1 09-30-2007 09:27 AM
Reynard on Fire! RRsis393 General Discussion 13 03-16-2006 08:09 PM
another fire death in MS MotoMojo17 General Discussion 1 04-17-2004 08:34 PM
FIRE!!!!!!! ddfh_4_life General Discussion 35 03-18-2004 07:33 AM
