All Things Moto! Web Forums
660 raptor starting problems
This is a discussion on 660 raptor starting problems within the ATV/UTV - Yamaha forum, part of the ATV/UTV Forums category; i have a 2001 raptor 660r. it is having problems starting. sometimes the only way it will start is by ...
Old 08-01-2009, 10:53 AM
Last Online: 08-17-2009 02:13 PM
Default 660 raptor starting problems
i have a 2001 raptor 660r. it is having problems starting. sometimes the only way it will start is by taking the air filter out and putting your hand over the right side carb. but once it is running it starts right up.every thing on it is stock.
Old 08-01-2009, 02:06 PM
Last Online: 10-28-2009 08:35 PM
did u check the spark plug? also play around with the air fuel screw on the carberator it may be starving for air.
Old 08-16-2009, 10:49 PM
yes i have checked the spark plug. i change it often but it dosent help. and once its running its fine until it cools down.
Old 08-16-2009, 11:06 PM
wasnt that the year that had the tranny problems? have you talked to yamaha about this. the only thing i think it could be would be the carbourator.
Old 08-17-2009, 12:32 AM
Freak's Avatar
Hook 'Em
Last Online: Today 05:03 PM
I'd check the valve clarence.
Old 08-17-2009, 02:08 PM
yes that is the year they had the tranny problems but it wasnt with all of them. i took the carbs off and cleaned them but it didnt seem to help. what plug should i use. im using the stock plug. should i use a hotter one or what. And how do i check the valve clearence
Old 09-12-2009, 03:18 PM
raptor02's Avatar
Last Online: 09-18-2009 04:31 PM
If I remember right the right side carb is the primary carb for the raptor. I know you said that you cleaned the carb but did you take carb cleaner and spray down through all of the holes that the jets screw into to make sure that no gas is gummed up in it. also check to make sure that your choke is working right. Or the best solution is to get rid of the crapy factory carb and get an Edelbrock carb. Best purchase I made for my 02 Raptor. Hope you get it fixed
Mark
Similar Threads for: 660 raptor starting problems
YZ 250 starting problems mboyd 2-Stroke Motorcycles - Yamaha 4 06-04-2008 07:39 PM
Starting Problems d4nny_mufc 2-Stroke Motorcycles - Yamaha 5 07-24-2007 05:00 PM
raptor 660 starting problem jradon ATV/UTV - Yamaha 2 07-06-2007 11:52 AM
Raptor starting problem still (moved over from general) derek01raptor ATV/UTV - Yamaha 49 03-01-2006 01:33 AM
YFZ 450 starting problems killerkx327 ATV/UTV - Yamaha 51 09-03-2004 12:33 AM
