02 Blaster blew up, need service manualThis is a discussion on 02 Blaster blew up, need service manual within the ATV/UTV - Yamaha forum, part of the ATV/UTV Forums category; My little brother's 2002 Blaster blew up (piston broke) and there is a puncture in the bottom of the case. ... |
| My little brother's 2002 Blaster blew up (piston broke) and there is a puncture in the bottom of the case. Does anyone know where I can download a service manual? Thank you, Brian Henry |
| what is it you want to attempt to do to it? |
| Thanks guys. I needed all the torque settings so I can put a new top end in it, and I also need to split the case because a few pieces of the piston fell down into the engine. |
| I MIGHT have a service manual for a blaster left out in the barn...if I do it's yours, I will check this evening and let you know. |
You are awesome! I'm sure you already knew that though. |
| Thanks 2fun, but unfortunatly I must have given the service manual to the guy who bought my blaster, I could have sworn that I had it but I guess I don't. Sorry man, now I feel like an ***. |
| Good point, but I still should have kept my mouth shut until I knew for sure....I guess that kinda goes against my nature though, keeping my mouth shut. |
| LOL i was going to try to help out, but the tourqe stuff.... |
| most common abbreviations TDC = top dead center ATDC = after top dead center BTDC = before top dead center BDC = bottom dead center ABDC = after bottom dead center BBDC = before bottom dead center C = Celsius (centigrade) cc = cubic centimeters CDI = capacitor discharge ignition cu.in. = cubic inch F = Fahrenheit ft.lbs = foot -pounds hp = horse power in. = inches kg = kilograms km = kilometers L = liter M = Meter MAG = Magneto ml = milliliter mm = millimeter N.m = Newton-meters oz.= Ounce PSI = pounds per square inch pt. = Pint qt. = Quart rpm = Revolutions per minute ----------------------------------------------------------------------------------------------- Regular oil change 650ml 0.69U.S qt. 0.57Imp.qt After overhaul or flush 700ml 0.74U.S qt 0.62Imp.qt Idle speed 1450 rpm -1550 rpm Spark plug BR8ES or B8ES Plug gap 0.7-0.8mm .028-.032in Stock jetting 88-02 Mixture screw 1 ½ turns out Jet needle clip 2nd groove Main jet 230 2003- mixture screw 1 1/2 turns out jet needle clip 3rd groove main jet 230 Stock lighting specs? Headlight 45W/45W X 1, 12V Tail light 3.5W X 1, 12V Oil light 3.5W X 1, 12V ----------------------------------------------------------------------------------------------- Piston sizes avaiable for the stock sleeve? Wiseco (forged) STD, .010", .020", .030", .040", .050", .060", .070", .080", .090". Yamaha (cast) STD .020", .040", .060", .080" ---------------------------------------------------------------------------------------------- Acceptable clearances Piston-Cylinder limit: .035 -0.040mm (0.0014 in -0.0016 in) Taper limit: 0.08mm (0.003 in.) Out of round limit: 0.05mm (0.002 in.) ring end gap .20 - .30 mm(.008 in - .014 in) Crank shaft runout limit .03 mm (0.0012 in) BE (big end) side clearance 0.4 - 0.7 mm ( o.o16 - 0.028 in) SE (small end) free play 0.8 - 1mm (0.031 - 0.039 in) Reeds Reed stop height 8.3 -8.9 mm (.33 -.34 in) valve bend limit .5mm (0.02 in) ----------------------------------------------------------------------------------------------- Torque specs cylinder head nuts 20 ft.lb cylinder base nuts 18 ft.lb spark plug 18 ft.lb exhaust nuts 15 ft.lb reeds cage bolts 6 ft.lb primary drive gear 58 ft.lb clutch nut 58 ft.lb clutch spring bolts 4.5 ft.lb clutch adjuster nut 5 ft.lb kick pedal nut 47 ft.lb shift pedal 10 ft.lb flywheel nut 54 ft.lb trans drain plug 15.ft.lb oil pump cover bolts 5 ft.lb clutch cover bolts 7.5 ft.lb stator cover bolts 7.5 ft.lb stator bolts 6 ft.lb main bearing stop 12 ft.lb case bolts 6 ft.lb shift cam stop 10 ft.lb engine mount bolts front 33 ft.lb rear 24 ft.lb ---------------------------------------------------------------------------------------------- Tune up and inspection Once a month or sooner Clean air filter Change transmission oil Adjust and Lube all cables Grease all zerks Lube all pivot points Clean and adjust chain tension Check all nut and bolts Tire pressure Every 3 months or sooner Bleed injection system Clean injector tank filter Replace spark plug Re-pack wheel bearings, axle bearing and swing arm bearings. Grease brake cams, shock bushings, rear brake caliper, upper steering bearings,kick pedal pivot Check compression Flush fuel tank and trans |
| Excellent post Hardly! As usual! |
| I am having some trouble getting the flywheel off. I have the nut off, but the rotor will not come off. Any ideas? Thanks guys, the download is a big help. |
| You are gonna need a flywheel puller...there is sadly no way around it. |
| Yep, you can pick one up at any yamaha dealer for around $5. |
| These guys are right You will need the proper flywheel To use it remove the center bolt from the puller base and screw the base into the flywheel. Remember this is a left hand threaded tool/flywheel so you install the puller counter clockwise. Once it's in and snug install the center bolt and tighten it down. Now using a wrench hold the base of the puller steady while you tighten the center bolt in the puller and the flywheel will pop right off. good luck. |
| I think I have a problem, I have a rag under the engine sitting on the table and on the rag I found a tiny tiny spring and a ball bearing that is smaller than a BB. Does it go in the kick start gear shaft? I pulled it off and it looks like it would, but I am not sure. Thanks again! |
#18
| Post a pic of that bearing and spring if you would. |
#19
| yes that's where it's from. It's the the locking mec. that holds the kick starter in place when it's turned in towards the engine. be very thankful you found them. usually they blast off never to be found again. grease them up well before you re-install them as well as the pivot shaft. |
#20
| Another ball bearing fell out the other day, but I have no clue where it is from. It is slightly larger. Would you happen to know where it goes? Will it hurt the engine if I lose them and can not get them back in? Thanks for the info! |
| YZ 125 Service Manual | 230cc | 2-Stroke Motorcycles - Yamaha | 2 | 11-24-2008 04:47 PM |
| NEED A SERVICE MANUAL | tblacc | 4-Stroke Motorcycles - Yamaha | 5 | 01-13-2007 02:54 PM |
| service manual....? | kingsizechuck | General Discussion | 11 | 10-11-2004 10:11 PM |
| KDX 200 service manual | dR_sPoCk | General Discussion | 0 | 03-28-2004 03:23 AM |
| Service Manual | HLGuthery 393 | 4-Stroke Motorcycles - Yamaha | 5 | 08-20-2003 02:41 PM |
