02 Blaster blew up, need service manualThis is a discussion on 02 Blaster blew up, need service manual within the ATV/UTV - Yamaha forum, part of the ATV/UTV Forums category; You must have the clutch apart? (pressure plate removed)
Chances are it's the bearing for between the inner and outter ... |
#21
| You must have the clutch apart? (pressure plate removed) Chances are it's the bearing for between the inner and outter clutch posh rods. The clush shaft is hollow. The clutch arm push rod goes in first, then the ball bearing, then the outter push rod that is attached to the clutch pressure plate. They are the only two i can think of that you will find in your engine. It won't damage the engien if you forget about the push rod ball bearing, but your clutch won't disengage either Last edited by hardlydangerous; 12-09-2004 at 04:40 PM. |
#22
#23
| Thanks, you guys have helped me out a lot! Do you happen to know what order the spring and small bearing go on in the kick start shaft? I did have the pressure plate off, and that is where the larger ball went. Thanks again! |
#24
| Thanks for all the help, I got it up and running a few days ago! |
#25
Glad to hear it! |
#26
| Very cool! |
| YZ 125 Service Manual | 230cc | 2-Stroke Motorcycles - Yamaha | 2 | 11-24-2008 04:47 PM |
| NEED A SERVICE MANUAL | tblacc | 4-Stroke Motorcycles - Yamaha | 5 | 01-13-2007 02:54 PM |
| service manual....? | kingsizechuck | General Discussion | 11 | 10-11-2004 10:11 PM |
| KDX 200 service manual | dR_sPoCk | General Discussion | 0 | 03-28-2004 03:23 AM |
| Service Manual | HLGuthery 393 | 4-Stroke Motorcycles - Yamaha | 5 | 08-20-2003 02:41 PM |
