Old 06-06-2005, 01:47 PM
chabat's Avatar
Last Online: 03-24-2016 08:08 PM
Default Suzuki JR50 2 speed!
My son has a JR50 and he is looking to move up. He is 6. He has been riding the JR50 for about 1.5 yrs. He wants a little more low end especially for mud and sand.
I found this article: http://www.suzuki-bikes.com/forum/printthread.php?t=27
JR50/KDX50 2 speed gear modification : Here is a good tip for those with the JR50/KDX50 bike. You can modify the gear selector and get a second lower gear ratio. My friend did it on his son's bike and allows it to drive up hills better. Here is the link: http://www.trialscentral.com/forums...?showtopic=2414
Second article: http://www.suzuki-bikes.com/forum/printthread.php?t=27
Diagram of what part to mod:
Diagram of shifter from bike bandit:
I am anxious to try this mod, but am a little unsure which part is to be ground. Maybe it will be apparent when I get it apart...
Old 06-06-2005, 02:09 PM
Faded's Avatar
Default Re: Suzuki JR50 2 speed!
I've posted this in the past but it's good to bring up as a lot of people don't know about it. Also, these bikes are waaaay detuned and have some potential. The part to be ground is #3 in your diagram, the hole needs to be enlarged to allow the shift lever to move UP (further) shifting into 1st gear.
Old 06-06-2005, 02:20 PM
chabat's Avatar
Originally Posted by Faded
I've posted this in the past but it's good to bring up as a lot of people don't know about it. Also, these bikes are waaaay detuned and have some potential. The part to be ground is #3 in your diagram, the whole needs to be enlarged to allow the shift lever to move down (further) shifting into 1st gear.
Hey Faded,
Part number 3 has a shaft and a flat piece of metal with a retangular slot that part #2 goes through. Are they saying to enlarge the slot on the ends to lengthen the rectangle or enlarge the top and bottom thereby making it more like a square?
Also, did you grind the notch with part #3 still installed in the bike, or did you remove it first?
Old 06-06-2005, 02:41 PM
Faded's Avatar
Originally Posted by chabat
Part number 3 has a shaft and a flat piece of metal with a retangular slot that part #2 goes through. Are they saying to enlarge the slot to lengthen the rectangle or enlarge the top and bottom thereby making it more like a square?
Put all the pieces in the exploded diagram together and try to push the shift lever UP, the shaft (part #2) will bind on the front/back of the rectangle. Enlarge the rectangle a little at a time until you can push the shift lever UP (which moves the shift fork, item #6) into first gear. From bottom to top the shift pattern is 2 - N - 1.
You can also take 0.020" to begin with off the head, without any problems, to add more bottom end.
Also, the carb is screwy, it has two pilot jets...if you start to uncork the bike yank out the first pilot jet. Eventually the main will have to be increased as well. I'm going on what I can remember, if you want I can dig up some more info for you. We played with one making it a JR52 but sold it before we were finished.
Old 06-06-2005, 02:44 PM
Faded's Avatar
You can do it either way depending on what tools you have to work with. A dremel or something similiar will let you keep it on the bike, just keep track of the shavings.
Old 06-06-2005, 08:10 PM
chabat's Avatar
Well. I did the mod but it did not work. The JR50 we have was made from 2 jr50s one with a good frame bad motor, one with a bad frame good motor. I think it is a mid 90's.
Anyway, piece #1 hits the case and it won't move enough to go into 1st gear (you can see it hit the case inside with a flashlight - meaning you would have to slpit the case and grind more stuff, in my case it seems). The slot is more than elongated enough now. Bummer.
I think I will just shop for a different bike for him, maybe an xr50 or something, those are 3 speeds, right?
Old 06-07-2005, 10:21 AM
Faded's Avatar
Wow, that's definately no good. Yes, the XR/CRF50's are 3spd auto clutch and are great bikes.
Old 12-14-2009, 01:18 PM
Last Online: 12-14-2009 06:00 PM
Default HELP.... S.O.S..!!!! with JR50 1st gear
I've searched high & low for help unlocking 1st gear on my son's jr50. I've seen a lot of info on this but would love to find some pics & maybe a diagram of some sort. ANY help would be greatly appreciated.. Thanks
Old 03-09-2010, 05:31 AM
Last Online: 03-09-2010 05:31 AM
Default jr50 mod
hi i cant seem to get onto any of the links above for the jr50 gear mod, anyone got any tips or pics??
thanks ryan
Old 03-20-2010, 06:00 PM
Last Online: 07-24-2012 01:02 AM
Default 1994 suzuki jr50
the link to the mods are not working can anyone help email me please
Old 04-09-2010, 03:48 PM
Last Online: 04-09-2010 03:57 PM
Default jr50 mods
if anyone can email me the info also it would be greatly appreciated, thanks
Similar Threads for: Suzuki JR50 2 speed!
suzuki jr50 dean soppe 2-Stroke Dirt Bikes - Suzuki 1 04-20-2009 08:55 AM
1983 jr50 stu1705 Mini Dirt Bike Riders 1 07-24-2007 09:20 PM
Changing kx450f 2006 4 speed to a 5 speed box Team Green 4-Stroke Dirt Bikes - Kawasaki 5 06-17-2007 01:27 PM
***For Sale***86 JR50 Shifting Classified Ads 0 12-18-2004 05:13 PM
jr50 parts TheReverend 2-Stroke Dirt Bikes - Suzuki 1 02-14-2004 07:44 PM
