Old 03-22-2017, 02:52 PM
Last Online: 03-22-2017 03:02 PM
Never seen the problem on any of my bikes. But troubleshooting I've read suggests it's probably pulling in trans oil through that seal causing the problem?? Worth looking into at the least. Sounds like you have safely eliminated anything real obvious.
Will
Old 03-22-2017, 05:02 PM
Big Maico 393's Avatar
Super Moderator
Last Online: Yesterday 06:39 PM
Originally Posted by cowboyona426 View Post
Yes, smokes like a freight train.
Chase,
Sound like it's sucking trans oil for a blown\weak wet side crank seal.
Go take the spark plug out & see if it smells like oil.
Old 03-22-2017, 05:32 PM
Last Online: Yesterday 10:03 AM
Originally Posted by Big Maico 393 View Post
Chase,
It never has when I've had it out. I'll get some crank seals ordered up, they are cheap enough and it won't hurt to replace them.
Old 04-03-2017, 09:11 AM
Update, bought a compression tester yesterday and I think I may have found the issue...
I did check my gauge using my air compressor and I'm confident it's reading accurately. And yes, I did hold the throttle open when doing the compression test. Next step is to measure the cylinder to see if it's out of round, then get some parts ordered up.
Old 05-04-2020, 09:33 AM
Bringing this one back from the dead. I have been working on getting this little bike going again slowly, my boy really wants to ride it. I replaced the piston and had the cylinder lightly honed, and it fired right up and was running awesome in the shop. Trying to ride it produced the same old result, it sounded like it was loading up (not smoking any more than usual this time) and wouldn't stay running. I had a parts bike that I robbed all the electrical parts off of, thinking it may be a problem with the stator or the coil? Still need to check those crank seals also.
Old 06-03-2020, 05:46 PM
Last Online: 06-09-2020 11:20 AM
Yelled profanities at the bike
I thought you were talking about me...
Well Im interested in this post as it sounds similar to the issue im having and at a lost of whats going on. bike ran like a top and now after replacing waterpump seals runs like a dog
Please keep us/me posted on any developments and if I think of anything ill also share
Old 06-04-2020, 10:29 AM
Fairly certain it's a failed crank seal, which requires splitting the cases to fix unfortunately.
Similar Threads for: Suzuki DS80 not running right- please help
Suzuki ds80 Ridingsince94 2-Stroke Dirt Bikes - Suzuki 5 07-18-2013 05:06 PM
Suzuki ds80 Ridingsince94 4-Stroke Dirt Bikes - Suzuki 6 06-15-2013 01:08 PM
Suzuki ds80 Ridingsince94 2-Stroke Dirt Bikes - Suzuki 0 06-12-2013 01:56 PM
Headlight for Suzuki DS80 Ks Dad Mini Dirt Bike Riders 4 09-26-2012 05:50 AM
F/S Suzuki DS80 islandsurfer Classified Ads 0 03-30-2005 01:51 PM
