RM125 Engine Blown HELP!!This is a discussion on RM125 Engine Blown HELP!! within the 2-Stroke Motorcycles - Suzuki forum, part of the 2-Stroke Motorcycle Forums category; Was riding my 01 RM125 the other day and it had a fresh top end with only 1 hour on ... |
| Was riding my 01 RM125 the other day and it had a fresh top end with only 1 hour on it and suddenly I turned and shifted down to first and was letting go of the clutch and once i went to accelerate it seemed like it just windded out and sank in RPM's untill it was completely stopped. Tried to re-crank it but nothing worked. Sounded like a bubbling sound in the cylinder like there was alot of liquid in there or something. Any tips would be nice |
| I would take a compression ck. first, Then take off the head and look at piston,and cylinder and go from there. Could have been a couple things, Didn't have to hot a plug? run too lean, head gasket? Just suggesting some places to start. Keep us informed. Hope it goes well and doesn't cost you to much.! .....Jerry |
Try and kick the bike over and see if it "feels" like the compression is gone. If you can kick it over with your hand.....then you will have to do a tear down. If you have a compression tester...Take a reading and see what your getting. You can also pull the pipe off and shine a flash light in the cylinder to see whats going on. good luck -Kevin- |
| Really? Try a KX500 and get back to me..... -Kevin- |
| Yeah,or my 250 Zuke,Not quite that easy. You asked a question on a forum an Kevin an myself,tried to give you some suggestions to help an save you time and $$ do what you will with the advice. Good Luck.....Jerry |
| Tags |
| blown engine, rm125 |
| what side does RM125 engine split? | rm-mulisha | 2-Stroke Motorcycles - Suzuki | 2 | 05-22-2008 08:03 AM |
| yz250F blown engine pics | YZ125motoracer | 4-Stroke Motorcycles - Yamaha | 17 | 12-08-2006 12:07 AM |
| Blown RM125 | Viggey | 2-Stroke Motorcycles - Suzuki | 24 | 03-27-2006 07:50 PM |
| Engine for 98 RM125 | CJ01 | MC & ATV Parts & Accessories | 1 | 03-15-2006 03:38 PM |
| Blown Engine | Old Man | ATV/UTV - Yamaha | 11 | 05-24-2005 04:11 PM |
