rm 250 jumping out of 2nd gear help!!!This is a discussion on rm 250 jumping out of 2nd gear help!!! within the 2-Stroke Motorcycles - Suzuki forum, part of the 2-Stroke Motorcycle Forums category; hi guys my rm250 keeps jumping out of second gear when im at low revs . but does not slip ... |
| come on guys one of you must know any ideas running out of time ive got a race coming up help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Last edited by xtchahos; 02-22-2009 at 03:00 AM. |
| hi there ive just changed the selector forks and the bike still jumps out of fekin gear any ideas???????????????????????? |
| I was under the impression if the shift fork was bad it wouldnt go into a gear. Hmmmm, must be 2nd gear itself. Time to tear apart the tranny, or at least take a look. |
| did you change the tranny oil ....when i start missing 2nd it tells me that i need to change my oil and when i change it it goes away.....idk how thats supposed to work but it seems to work for me..it confuses me all the time though .... |
| If you move the shifter up and down by hand (do not shift gears) does it move quite a bit? If so pull kicker and clutch cover and the clutch will have to be removed also remove shifter and pull shifter shaft and remove the screwed in pin that holds the shift spring clean threads and put locktight and reinstall What is most likely happening ,the shifter is not centering the shift drum cause the pin is loose and not making full shift OSF |
| I didn't read your second post very well? You tore the trans down and changed forks? Did You inspect the shift drum for chips in the grooves? OSF |
| hi i ripped down the trans checked the shift drum for chips!cant see anything wrong with it a so i went out for spin yestardy and the rm blew the powervalves and smashed the pistion ive had enough of this rm oh and it stoped jumping out of second then blew???????????dammm 2strokes but you gotta luv em! time for new bike any ideas??has to be 2stroke?? thanks for help guys Last edited by xtchahos; 03-23-2009 at 03:30 AM. |
| Tags |
| rm250, rm250 2nd gear |
| F/s/t: Motocross gear and streetbike parts/gear! | idohcvtecexi | Riding Gear & Clothing | 0 | 01-03-2008 01:22 AM |
| Jumping...Please Help.... | Shoei_391 | General Discussion | 31 | 06-03-2007 05:39 PM |
| Jumping Help.. | Shoei_391 | General Discussion | 19 | 05-11-2007 06:19 AM |
| Jumping help | SirFallsALot243 | General Discussion | 60 | 04-27-2005 10:34 PM |
| Jumping | yami250fgal393 | General Discussion | 7 | 05-24-2004 11:48 PM |
