RM 250 case splitting
This is a discussion on RM 250 case splitting within the 2-Stroke Motorcycles - Suzuki forum, part of the 2-Stroke Motorcycle Forums category; This is taking off from the other post ( crank seals). I have been searching-reading and am going to put ...
Old 10-21-2007, 11:00 PM
Last Online: 11-12-2009 06:24 AM
Default RM 250 case splitting
This is taking off from the other post ( crank seals). I have been searching-reading and am going to put new crank bearings along with seals in the bottom end. There is a wealth of great info. on here. I had read where several of you had used an automotive steering wheel puller on the crank end with longer bolts to separate the case halves. Does this work fairly well on the RM? Money for this project is somewhat limited and the motion pro case splitter was more $ than I thought it would be. I was also reading about using heat on the case halves to seperate them easier, then using heat again and freezing the bearings for setting the bearings. Any other tips like these anyone can think off? I was also wondering what the best way was to keep the tranny gears/parts all together while messing with the case halves. Thanks!!!
Old 10-21-2007, 11:43 PM
Default Re: RM 250 case splitting
It has worked well on the RM's that I have done. I can't tell if you have a flywheel puller yet, but that is something you can't improvise on if you need an assurance that you can use the same flywheel over again. You can get them for under 20 dollars.
Old 10-21-2007, 11:46 PM
We used to have an old yamaha blaster and I got a flywheel puller for that. I will have to see if the threads are the same. If not, I will get one of those.
Old 10-21-2007, 11:48 PM
I should have read your last sentences a little closer. I like heating the areas around the bearing sockets. I like to leave everthing I can in the right side case until I am ready to lay everything out. I use rubber bands, (sometimes cut from inner tubes) around the gears, twisted and crossed to hold them in place. I don't photo things often, but if you have a digital camera it can help when reassembling. Just for good measure (as they say) I replace the shifting fork that handles the low to second shift pretty much everytime. Sometimes the others as well, depending on how they measure out.
I haven't done an RM since 93, so I can only suggest a manual to you. Suzuki used to send pretty good ones.
Old 10-22-2007, 12:00 AM
I sure would not want to tackle this without a manual. The RM came with a clymer, which seems to lay things out fairly well. You said you like to leave things in the right side case, I thought that I would have to clean everything out right away so I could press or drive the old crank bearings out?
Similar Threads for: RM 250 case splitting
Splitting a case? jczlsr 4-Stroke Motorcycles - General Discussion 4 05-05-2008 01:39 PM
Splitting cases on YZ125 CRacer 2-Stroke Motorcycles - Yamaha 1 02-07-2006 12:08 PM
mid-80s KDX200:splitting the case jdosher 2-Stroke Motorcycles - Kawasaki 2 04-25-2005 07:34 PM
Splitting the Case 99kx250rules 2-Stroke Motorcycles - General Discussion 7 02-01-2005 11:40 AM
SPLITTING THE CASES PLEASE HELP!!!!!!!!! CR 250 rider 4-Stroke Motorcycles - Yamaha 50 05-25-2004 01:30 PM
