RM 125 CylinderThis is a discussion on RM 125 Cylinder within the 2-Stroke Motorcycles - Suzuki forum, part of the 2-Stroke Motorcycle Forums category; I recently had the cylinder micd and here are the numbers.54.02,54.03,53.997.It looks like the specs are 54mm x 54.1mm bore ... |
| I recently had the cylinder micd and here are the numbers.54.02,54.03,53.997.It looks like the specs are 54mm x 54.1mm bore and stroke.Is this cylinder in tolerance? |
| Well - it's only out by .001" (.03MM = .001"). It's worn, but considering the plating is usually thicker than .003"-.005" (IIRC), I think you are OK for now. I assume the lowest number was at the bottom (original size), the next number is mid and the largest number is the top - below the wear ridge. With this wear, your ring groove will wear a tad faster than a new bore, so keep an eye on the ring groove when re-ringing. Scott |
| Thanks for the response Scott. Do you have any suggestions before I install the new piston and ring? |
| Is there any hatch left in the worn area? I doubt it. A new ring in a non-hatched cylinder will not seat properly. You might want to investigate honing the cylinder. Keep in mind - if you race or ride hard and there's no hatch left it's replacement or re-sleeve time. For recreational use you will be likely be fine. Scott |
| used or new cylinder | kxftop | General Discussion | 3 | 10-16-2007 10:00 PM |
| Help, No gas to cylinder on my 81 yz 125 | kcmastr | 2-Stroke Motorcycles - Yamaha | 6 | 10-16-2006 06:23 PM |
| Do I need a new cylinder? | klu954 | 2-Stroke Motorcycles - Honda | 2 | 02-21-2005 02:01 PM |
| Cr 250 Cylinder | Bucmaster | 2-Stroke Motorcycles - Honda | 3 | 01-25-2005 01:19 AM |
| Cylinder | dirtracer_2000 | General Discussion | 2 | 11-21-2004 04:16 PM |
