Old 02-05-2009, 06:31 PM
Last Online: 02-07-2009 05:03 PM
Default RH crank bearing removal TS185
1977 TS185 - I received the clutch discs (now soaking in oil) and the LH & RH crank seals. I have the full clutch assembly off and the pinion gear off. Can't seem to get the RH crank bearing to come out. Tried heating the housing around the bearing with a torch 7 then hitting the bearing race with some electronic freeze spray, but that sucker's in there tighter than Dick's hat band! Any suggestions?
Thanks,
Old 02-07-2009, 05:03 PM
Bit the bullet and removed the motor to split the cases. Didn't take too long and no need for the special Suzuki tools listed in the Clymer manual. Just used a large plastic mallet to persuade the cases to come apart. Now to order the bearing(s), seals and gaskets.
Similar Threads for: RH crank bearing removal TS185
Crank bearing removal mark 1987 930 2-Stroke Dirt Bike Forums 8 03-14-2009 08:07 PM
Swingarm bearing removal dangerSteve 2-Stroke Dirt Bikes - Honda 9 02-25-2009 05:46 PM
Shock Linkage Bearing Removal coss 4-Stroke Dirt Bikes - Honda 7 01-01-2008 09:19 PM
axle bearing removal yfs200bl ATV/UTV - Yamaha 0 05-15-2007 04:26 PM
Axle bearing Removal quadfather03 ATV/UTV - Honda 9 01-02-2006 10:15 PM
