Old 11-29-2014, 04:31 AM
Last Online: Yesterday 08:49 PM
Ok after see the video....Check your exhaust as it sounds like it is clogged up. This can be from varmits building a nest in the pipe or the silencer may have come apart and blocking the exhaust.
Also, I did not see an air filter in place....Do you have a rag stuck in the carb?
Old 11-29-2014, 07:58 AM
Last Online: 06-13-2020 08:00 PM
I would double check the ohms readings on the stator. It seems to me that the stator is not working correctly. Is it shooting a bunch of oil out the exhaust?
Old 11-29-2014, 03:28 PM
Last Online: 01-25-2020 05:01 PM
I agree the back firing is a tell tale sign of a timing/ignition problem, check all of your wiring/grounds etc. also when working on a 2-stroke you should replace the spark plug after each try until you get it rite, because it can burn, or foul plugs as you are trying to fix the problem, in turn will have you looking for something that might not be the problem, you can use a cheaper champion plugs until you figure out the problem, then go back to the ngk,
Old 03-09-2015, 12:34 PM
Last Online: 03-10-2020 08:42 PM
Default Stator
So I replaced the stator as I said, but checked the readings and the rearranged are okay. Does anyone know what kind of voltage values I should be getting out? I have 32 on one side but only like 5 on the other side for accessory?? Are these normal??
Old 07-20-2016, 09:03 PM
Default Video of Dirt Bike
Has anyone heard this noise before? I am still having issues figuring this out. Any input is appreciated!
https://www.youtube.com/watch?v=G6Z-yd_xYS4
Old 07-21-2016, 05:14 PM
The replacement stator is junk. It sounds like the pick up coil is wired backwards which would change the timing a good bit.
Old 07-21-2016, 06:18 PM
Default Pick up wiring
Paw Paw,
Thanks for responding so quick! If the pick up is wired backwards am I able to just swap wires or is there something more to it? Also you referred to the part as the "pick up coil," I am picturing the little black box outside of the actual stator and flywheel. Is this correct?
Old 07-21-2016, 06:25 PM
Yes
Old 07-21-2016, 06:49 PM
I just went out and swapped the wires. It runs almost identical as it did before I swapped the wires.
Old 07-21-2016, 07:20 PM
If that is the case , then reset your timing.
Similar Threads for: Revving Issue on 1997 RM125
1997 RM125 resurrection D3luxe Dirt Bike Restorations and Builds 3 11-12-2014 11:25 PM
1998 rm125 bog issue jlt2016 2-Stroke Dirt Bikes - Suzuki 5 10-17-2014 12:22 PM
New crankshaft for RM125 1997? D3luxe 2-Stroke Dirt Bikes - Suzuki 22 10-02-2012 04:25 PM
1993 RM125 Coolant/Oil issue robxfinch 2-Stroke Dirt Bikes - Suzuki 0 07-12-2010 08:13 AM
1997 RM125 dirtyRM Classified Ads 0 10-10-2008 04:51 PM
