Old 01-22-2008, 01:13 PM
D3luxe's Avatar
Last Online: 10-01-2014 09:12 AM
Default New crankshaft for RM125 1997?
I blew the lower connecting rod bearing on my 1997 RM125, so I am looking to replace the whole crankshaft. It did some damage to the crank itself when it broke, which is why I need a new one.
Is there any place for me to get a new crankshaft assembly for cheaper than OEM? I have checked various 3rd party companies (hot rod, wiseco, a few others) and I cant find ANY crankshaft assy's for a 97 rm125.
Also, if I can only go with OEM, would it be better for me just to get a new lower connecting rod bearing and have a machine shop press/rebalance the crank? The damage on it isnt severe, it just has a couple minor chips around the edge.
Old 01-22-2008, 02:45 PM
Default Re: New crankshaft for RM125 1997?
unless the wheels themselves are tweaked and the ends cannot be aligned you will be able to put a new rod and bearing in it. fyi what most people call "balancing' is simply aligning the crank halves again. two different procedures. few of us have ridden a bike with a crankshaft that has actually been "balanced" beyond what the factory sends.
Old 01-22-2008, 02:56 PM
D3luxe's Avatar
Alright sweet, i'll look more into just replacing the bearing then..AFAIK, the rod itself is still in good condition, the bearing just locked up and broke so the rod has about a half inch of slack on it.
Any idea how much it would cost to have a machine shop press and align the crank again?
The crank itself is still together and in pretty good shape (Like I said, just a couple dings in the rim of it) but not bad at all. The reason I was going to get a whole new crankshaft is because of the slack from the broken bearing.
Old 01-22-2008, 03:09 PM
Blitz393's Avatar
Rocky Mountain ATV/MC <--parts
LukesRacing.com <--parts
FastForwardRacing <--labor
i think Tryce charges 35$ labor for a crank rebuild, that is you sending the crank and him replacing the rod and bearing, and truing the crank to .002" Highly recommend this, because a rod kit runs about 77$ from Lukes (at least for my 03) and with 35$ labor, you are spending about half of what a new aftermarket crank would be.
Rob
Old 01-22-2008, 03:12 PM
Blitz393's Avatar
correction, $50 on labor.
Old 01-22-2008, 03:23 PM
DON'T even think about using the original rod.
Old 01-22-2008, 03:40 PM
D3luxe's Avatar
Looks like I'll probably be going with him then.
Ok, so what all do I need then to get this thing fixed? I obviously need a rod kit (Thinking about going hot rods, thats what my current rod is). Would I send him just the rod kit and the crankshaft then?
And once I get the crankshaft back, do I just need new clips and a complete gasket kit right?
So..$100 for the rod, $50 for labor, and about $70 for a complete gasket kit from Rocky Mountain..That puts me at $220. Is that all I need?
That is amazing! I was looking at replacing the whole crank, OEM, which in itself was $550. Sadly there are no aftermarket cranks for a 97 rm125 =(
Old 01-22-2008, 04:00 PM
Blitz393's Avatar
i'm sure there is, but you just have to know where to look.
make sure you get a gasket kit that comes with OIL SEALS. the cometic brand "complete gasket set" is NOT 'complete'. i found this out the hard way... yes, it comes with all the necessary paper gaskets and o-rings, but none of the shaped oil seals. Moose sells a kit, available at rocky mountain, for (i believe) 80 bucks. it is a "complete kit with oil seals" and it's the one you want.
a list of parts to send to FFRacing (after calling/emailing/PMing him to let him know it's coming... )
-your old crank
-your new Hot Rods Rod kit. it should contain a Rod, Bearing, and Thrust washers. some kits come with a Wristpin bearing as well.
he will rebuild your crank, true it, and send it back. after that, you need
-newly refurbished crank.
-Crank Bearings
-Gasket set,
-all new oil seals. the original ones might be in good shape, but for $22 it's cheap insurance to replace them while you have the entire engine apart.
-piston kit
-top-end bearing (aka Wristpin Bearing)
-your bike, a manual, tools, a press, and some elbow grease.
do a search for crank installation, it wasn't long ago (few days) someone was on ATM asking about how to rebuild the bottom end. that way you dont' have to start a new thread about it... the information here and your manual should be more than enough to get you in the right direction. just take your time and don't force anything. read ahead in the manual, and don't take shortcuts. and, good luck
Rob
Old 01-22-2008, 04:07 PM
D3luxe's Avatar
Should I replace the piston as well? The piston and rings are both brand new (Maybe 2-3 hours of riding time.)
Also, for the crank bearings, do I have to buy new ones of those if my current ones are still good? Only the lower rod bearing broke.
And as you mentioned, I might as well go with the complete kit with the oil seals.
I have a mechanic right now that is a family friend with the press and tools needed to rebuild it, so basically I just need to know what to give him after the crank is rebuilt, which you pretty much covered.
Old 01-22-2008, 04:29 PM
Blitz393's Avatar
at least get a new ring. that's all up to you though. i would definitely suggest new crank bearings, they are cheap (40$) and to replace them you would have to split cases (again) and go through another set of gaskets, etc. they also freshen up the motor in a way you won't appreciate until you replace them. you don't notice until you have a new bottom-end how much of a difference it makes having fresh bearings. even if it means you have to wait an extra week or so to pay for the parts... that's what i'm going through right now with my 125. instead of rushing and having a half-*** bike, take the time required to get the necessary parts and do it right the first time.
plus when you sell or trade it for a new 450 like i'm doing( ) it helps to be able to provide receipts of every major engine part on the bike to a potential buyer.
Rob
Similar Threads for: New crankshaft for RM125 1997?
1997 RM125 dirtyRM Classified Ads 0 10-10-2008 04:51 PM
00 YZ250 crankshaft help fordham360 2-Stroke Dirt Bikes - Yamaha 6 05-15-2008 07:34 PM
yz426f need new crankshaft ?? barty5 4-Stroke Dirt Bikes - Yamaha 9 02-22-2007 03:35 PM
1997 RM125 idling problem inf0r 2-Stroke Dirt Bikes - Suzuki 5 03-21-2006 03:05 PM
1997 RM125 price and comments inf0r 2-Stroke Dirt Bikes - Suzuki 6 09-19-2005 10:19 AM
