Keihin Carb HELPPPPThis is a discussion on Keihin Carb HELPPPP within the 2-Stroke Motorcycles - Suzuki forum, part of the 2-Stroke Motorcycle Forums category; I have a 1998 Suzuki RM 250. Recently I have had problems with the keihin pwk carb leaking fuel out ... |
| I have a 1998 Suzuki RM 250. Recently I have had problems with the keihin pwk carb leaking fuel out of the overflow. I took the carb off and readjusted the floats and cleaned all the jets, reinstalled and the same problem. I took the carb off and took it to a suzuki shop and they told me the needle seat was wore out and could not be replaced, I would need a new carb. So I bought a brand new Keihin carb put it on and it does the EXACT same thing! I took the bowl off and checked and readjusted the floats again and it still does the same thing. Helppp what am I missing? |
| I bet the dealership was quick to tell you to buy a new carb. |
| Yea and 300 bucks later its still doing the Exact same thing |
| Mine is doing the same thing and I am pretty sure that either the float height is messed up from the float being stuck in the carb or the float is not adjusted properly. Try tapping the carb body to free the float to allow it to shut off the fuel flow, if it doesnt work you are gonna have to take it apart and reclean it. |
| Well I found a bunch of black crap in the bottom of My carb coming from the inside of the rubber hose that leads to the carb from the tank. I never would have thought that but I did replace that hose with a rubber one I had laying around a few months ago. I went and got the neoprene hose from the bike shop and I'm going to try that. |
| Just to let yo know, this morning I got my bike started, just like I thought I tapped the carb quite firmly a few times and the fuel stopped flowing out the overflow. It must have been stuck, I guess my Clymer was right. It then fired right after two kicks. I am quite surprised it worked, its weird that they would manufacture a carb to get stuck like that. So if your still overflowing after whatever you are doing, give that a try. |
| I will keep an eye on the overflow and make sure it is not leaking, if so I will do as you say. Thanks |
| Mikuni/Keihin carb, difference? | RoostRM125 | 2-Stroke Motorcycles - General Discussion | 13 | 04-22-2008 05:15 AM |
| keihin pwk carb..... | 2001hondacr125 | General Discussion | 0 | 02-02-2008 05:06 PM |
| KEIHIN Carb Jets??? | Ranger_450F | General Discussion | 3 | 08-19-2006 10:05 AM |
| Keihin PWK 38 mm Carb | rdyz4me | MC & ATV Parts & Accessories | 0 | 07-27-2006 10:22 PM |
| Keihin PWK Carb Question | HondaOnly | 2-Stroke Motorcycles - General Discussion | 6 | 09-16-2004 11:07 AM |
