ds80
This is a discussion on ds80 within the 2-Stroke Motorcycles - Suzuki forum, part of the 2-Stroke Motorcycle Forums category; hello I am new today. Having trouble with my sons ds80 it had lousy compression so I have redone the ...
Old 07-04-2007, 06:30 AM
Last Online: 07-06-2007 04:56 AM
Default ds80
hello I am new today. Having trouble with my sons ds80 it had lousy compression so I have redone the top end . but it is putting out an excessive amount of smoke. tried to adjust oil injection but does not help and after idleing awhile boogs out any suggestions?
Old 07-04-2007, 06:43 AM
nathan's Avatar
Just Let Me Hold It Wide
Last Online: 02-04-2009 11:43 AM
Default Re: ds80
hmm i dont really know man did you re check your head bolts they might be loose my blaster did something simlilar when i had it i started to re build the top end and notices the head was loose
Old 07-04-2007, 07:12 AM
spartanbiker_117's Avatar
1997 CR125R
Last Online: 01-06-2010 11:27 AM
Default Re: ds80
Sounds like a carb problem. Take it apart and check the float level and give it a good clean. If this doesn't help then run it for a while and check your spark plug. If it's light tan or white, then you're running lean. If it's dark, oily black, then you're running rich. After you have figured out what way you need to go and you're positive your float level is on, then you can start jetting. Hope this helps
Old 07-04-2007, 08:41 AM
boogieonmyfinger's Avatar
Last Online: 03-11-2009 02:26 PM
Default Re: ds80
What color is the smoke? If it's white, then you'll need to replace the main seal.
Old 07-04-2007, 01:18 PM
Last Online: Yesterday 11:36 PM
Default Re: ds80
Until you see what transmission oil and what engine oil look like burning on the same day, just saying white or blue doesnt always make sense.
For the DS I am betting the float hasn't been set since the carburetor manufactured did it. Once a season isn't too much, so start there.
Old 10-25-2009, 01:18 AM
Last Online: 11-11-2009 07:16 AM
Exclamation
HI all I have just finished a top end rebuild on my DS 80 but still having problems. The thing wont kick start but will clutch start, it also wont idle and blows lots of smoke.I have tried ajusting the idle screw, and oil injection and also cleaned the carbie but still have problems. Any suggestions would be much appreciated.
Similar Threads for: ds80
DS80 cwatkins 2-Stroke Motorcycles - Suzuki 15 10-25-2009 01:24 AM
Need help with Older ds80 olderds80 2-Stroke Motorcycles - Suzuki 0 09-23-2008 04:01 PM
1981 SUZUKI DS80 PARTS oscar442 Motorcycles & ATV's 0 09-10-2008 05:32 PM
Headlight for Suzuki DS80 Ks Dad Mini Motorcycle Riders 2 12-19-2007 01:22 PM
F/S Suzuki DS80 islandsurfer Motorcycles & ATV's 0 03-30-2005 01:51 PM
