DS80
This is a discussion on DS80 within the 2-Stroke Motorcycles - Suzuki forum, part of the 2-Stroke Motorcycle Forums category; Getting ready to put my daughter DS80 back together (new top end) and would like to know if I dont ...
Old 03-14-2007, 04:49 PM
cwatkins's Avatar
Last Online: 03-05-2010 07:41 PM
Default DS80
Getting ready to put my daughter DS80 back together (new top end) and would like to know if I dont hook up the oil injector and just run mixed gas if Ill need to rejet or anything else.I just dont trust injectors because by the time you figure out that there not working its to late.The bike is a 1985 .
Old 03-14-2007, 07:48 PM
Semper Fidelis
Usflag Re: DS80
Suzuki's injection system (CCI) used a oil spray into the crank. You have to drill out the passage in order to run pre-mix only and take the injector off. CCI is Crank Case Injection.
Bill
Old 03-14-2007, 08:40 PM
cwatkins's Avatar
Default Re: DS80
theres a line that come out of the injector that goes into the carb. thought that was how it got oil?
Old 03-15-2007, 10:00 AM
Semper Fidelis
Usflag Re: DS80
You have a line to the carburetor and a line to a passage into the crank. If the line is gone someone did the ,modification to the bike. Suzuki sold hop-up kits with small injection containers and instructions on how to remove the CCI entirely in the 70's
Bill
Old 03-15-2007, 01:54 PM
cwatkins's Avatar
flasher Re: DS80
Ill just put it all back together like it was has worked fine for the last 10 years so should still be fine Thanks for the info
Old 03-15-2007, 03:52 PM
Semper Fidelis
Usflag Re: DS80
Let us know that the DS runs okay when you get her reassembled. Best of luck.
Bill
Old 03-17-2007, 07:04 PM
cwatkins's Avatar
Default Re: DS80
[IMG][/IMG][IMG][/IMG]Heres some pics will post more when its done. Look where the reeds go have never seen that before [IMG][/IMG][IMG][/IMG]
Old 03-19-2007, 04:49 PM
cwatkins's Avatar
Default Re: DS80
Is this the mod you were talking about so I can run premix
Old 03-19-2007, 06:21 PM
Semper Fidelis
Usflag Re: DS80
Sir,
The reed set up is a case reed induction. Suzuki went in for this starting with the RM250A and 370A in 1976 models and expanded their use across the 2 stroke off-road line, including the RM 125, 100 and 80. I owned a lot of mid 70's Suzukis with this system.
As best as I can tell that motor in the picture has the bottom end modification allowing pre-mix use done to it, either by an owner or the factory. I don't think it is factory however since the DS line was a casual off road line.
Bill
Old 03-19-2007, 08:24 PM
cwatkins's Avatar
Default Re: DS80
Thank you for all your help! The pic of the motor is the motor off my daughters bike and as far as I know of its the first time it has ever had a top end jod.The bike was my sons first and oldest daugters first now Im teaching my youngest to ride.Cant wait till we all can go riding together this summer again thank you!
Old 03-20-2007, 04:18 PM
twostroker's Avatar
1984 CR125
Last Online: 05-20-2007 04:32 PM
Default Re: DS80
cwartkins, i have a 1986 DS80, ive been mixing gas for that bike for two years now. Nothing has happened to it and it still rips along. What i would do is i just would leave the oil tank empty but pre mix the gas. if you need any help, or parts tell me. Ive ripped that bike apart many times and i have a few spare parts. By the way, the DS80 sounds mint with out the silencer
Old 03-23-2007, 07:20 PM
cwatkins's Avatar
Default Re: DS80
Got it all done runs like new. my little girl is stoked [IMG][/IMG]!!
Old 03-23-2007, 09:06 PM
char393's Avatar
Incretacular!!
Last Online: 03-08-2010 09:33 AM
Default Re: DS80
Yay!
Old 05-17-2007, 01:33 AM
Last Online: 05-22-2007 08:31 AM
Angry Re: DS80
Hi all
My son has a DS80 about a 1996 it used to has stacks off power but resently it's just dead. It start after about 20 kicks and you have to run along side it to pull off but when you put it in 2nd it just dies.
Any ideas?
I have opened it, very thing looks like new, I did change the crank seal behind the botton coil the other one is inside the casing I did not open that.
Thanx
Bosvark
Old 05-18-2007, 12:02 PM
larry1000's Avatar
Last Online: 05-18-2007 08:58 PM
Default Re: DS80
do a compression test and go from there.
Old 10-25-2009, 01:24 AM
Last Online: 11-11-2009 07:16 AM
Hi all, I have just finished a top end rebuild on my DS 80 but still having problems. The thing wont kick start but will clutch start, it also wont idle and blows lots of smoke.I have tried ajusting the idle screw, and oil injection and also cleaned the carbie but still have problems. Any suggestions would be much appreciated.
Similar Threads for: DS80
ds80 ds80 2-Stroke Motorcycles - Suzuki 5 10-25-2009 01:18 AM
Need help with Older ds80 olderds80 2-Stroke Motorcycles - Suzuki 0 09-23-2008 04:01 PM
1981 SUZUKI DS80 PARTS oscar442 Motorcycles & ATV's 0 09-10-2008 05:32 PM
Headlight for Suzuki DS80 Ks Dad Mini Motorcycle Riders 2 12-19-2007 01:22 PM
F/S Suzuki DS80 islandsurfer Motorcycles & ATV's 0 03-30-2005 01:51 PM
