Carb trouble
This is a discussion on Carb trouble within the 2-Stroke Motorcycles - Suzuki forum, part of the 2-Stroke Motorcycle Forums category; I am having trouble with my 01 rm125. When i turn the gas on gas poors out of the carb ...
Old 01-09-2005, 07:31 PM
Last Online: 04-05-2007 03:19 PM
Default Carb trouble
I am having trouble with my 01 rm125. When i turn the gas on gas poors out of the carb hose coming out of the bottom of the float. What could cause this. I also have the same trouble with an old rm 80 and I have had the carb apart many times and cleaned it and it still does it on this old rm. I haven't had the 01 apart yet.
Old 01-09-2005, 07:43 PM
quadfather03's Avatar
Last Online: 01-18-2010 05:28 PM
Default Re: Carb trouble
Sounds like the float is stuck. Do you have an inline fuel filter to get the trash? I would probably say it was either trash or you may have to adjust the float. Good Luck.
Old 01-09-2005, 08:25 PM
River's Avatar
Last Online: 12-12-2006 02:24 PM
Default reply
You have dirt between the needle and seat, or the the needle and seat needs replaced...remove the float, the needle will hang from a spring, this allows the fuel into the bowl, clean there and blow free with compressed air.
Old 01-09-2005, 09:36 PM
souphmars's Avatar
Last Online: 02-25-2009 10:57 PM
i had the same problem- it was the float needle
Old 01-10-2005, 09:45 AM
Faded's Avatar
Last Online: Today 07:33 AM
Set Your Float Level
Old 01-15-2005, 09:13 PM
YZER-409's Avatar
Last Online: 07-25-2005 07:44 PM
I had the same problem on my old yz80 took apart the carb and found a peice of dirt that got the float to stick.
Old 02-10-2005, 04:15 AM
PAUL MACE's Avatar
Last Online: 02-23-2005 04:20 AM
Check the tank breather hose. Also make sure all your all you carby vents are clear, they often get clogged up which will create excessive pressure in your carb.
Similar Threads for: Carb trouble
Flat Slide Carb vs. Piston Valve Carb cr85racer24 2-Stroke Motorcycles - Honda 1 09-20-2009 09:38 PM
Carb trouble DH32 2-Stroke Motorcycles - General Discussion 3 02-22-2009 01:51 PM
Carb trouble danpeltz General Discussion 4 01-09-2005 08:26 PM
400ex carb trouble wheelieking General Discussion 0 08-26-2004 09:55 AM
I Anyone Having trouble .... OLDMXRACER 393 General Discussion 60 11-10-2003 08:56 PM
