Another clutch question
This is a discussion on Another clutch question within the 2-Stroke Motorcycles - Suzuki forum, part of the 2-Stroke Motorcycle Forums category; I broke one of the clutch spring bolts off in the basket of my son's 98 RM 125. If I ...
Old 04-27-2009, 10:16 AM
Last Online: 07-16-2009 09:41 PM
Default Another clutch question
I broke one of the clutch spring bolts off in the basket of my son's 98 RM 125. If I cannot get it out with an easy out, how hard is it to remove the basket to replace it?
Thanks
Kent
Old 04-27-2009, 10:50 AM
MXtras's Avatar
Manufacturer
No biggie. Pull the hat and you will see a large nut in the center. Put a penny between the primary drive gear and then push down on the plates while using an impact to remove the nut. Now remove the clutch stack and pull the inner basket out. Whatch out for the bearing and some washers that will likely stick to the inner basket - handle with care.
Scott
Old 04-27-2009, 11:26 AM
Thanks MXtras,
I already have the plates out of the basket, can I just hold the basket while using my impact on the nut? How tight does this nut need to be when I go back together?
Thanks
Kent
Old 04-27-2009, 03:36 PM
MXtras's Avatar
Manufacturer
I would put the plates back in. That nut should be pretty tight (don't have the spec, but it's around 85-95FtLbs if I recall). I few bumps with the impact will pop it right off.
Scott
Old 04-27-2009, 04:00 PM
Thanks will do. I am not real clear about where to put the penny you mentioned.
Kent
Old 04-27-2009, 10:05 PM
MXtras's Avatar
Manufacturer
The penny keeps the whole she-bang from spinning and it limits the impact to the primary gears. These are the gears between the crankshaft and the clutch.
Scott
Old 04-28-2009, 08:09 AM
Thanks for the help, I will tear into it this weekend.
Kent
Old 04-29-2009, 02:30 PM
Last Online: 09-23-2009 06:24 PM
when you get it off, if you look from the backside, the hole should go all the way through. Just get a left handed drill bit, that will usually wind it right out without any chance of buggering up any threads
Old 04-29-2009, 03:10 PM
I never thought about that, I will see if I can find a left hand bit. Thanks for the tip.
Kent
Old 04-29-2009, 05:45 PM
FFRacing11x's Avatar
The "ONLY" FastForward
That penny will not work for loosening the clutch nut. Leave the clutch plates in and use an air impact. Tq when tightening is around 55#. This spec is critical as so the hub does not bind. This tool can be easily made from some old steel drive plates...
Old 04-30-2009, 07:03 AM
MXtras's Avatar
Manufacturer
Originally Posted by FFRacing11x View Post
That penny will not work for....
I know what you are saying, but I use a piece of copper to keep the teeth from brinnelling from the impact -not necessarily to hold the basket.
Obviously, the inner basket is not connected to the primary drive gears.
Scott
Old 04-30-2009, 08:25 AM
I had planned on using an air impact for removal and I will be sure and use my torque wrench on reassembly.
Kent
Old 04-30-2009, 03:57 PM
Spikester's Avatar
Last Online: 11-12-2009 04:21 PM
I always just stuffed a shop rag in the gears to hold everything, lots of parts are cheap on ebay, sometimes they go for opening bid on older bikes, check there if you need one.
Old 05-01-2009, 08:54 AM
Thanks, will check it out.
Kent
Old 05-07-2009, 08:19 AM
Well, the easy out worked and I removed the broken bolt and put everything back together. What is the proper way to adjust the clutch cable?
Thanks
Kent
Tags
clutch basket removal, rm125
Similar Threads for: Another clutch question
06 rm 125 clutch question hondafmx_89 2-Stroke Motorcycles - Suzuki 1 12-21-2008 02:06 AM
Clutch Question Fireman87 2-Stroke Motorcycles - General Discussion 3 11-01-2007 06:56 PM
Clutch question ? four26stroker 4-Stroke Motorcycles - Yamaha 7 08-11-2006 12:44 PM
New clutch question gonzo 2-Stroke Motorcycles - General Discussion 0 01-25-2005 10:40 PM
Clutch Question JAJA208 General Discussion 4 09-18-2003 02:42 PM
