96 RM125 won't start
This is a discussion on 96 RM125 won't start within the 2-Stroke Motorcycles - Suzuki forum, part of the 2-Stroke Motorcycle Forums category; I recently took a 96 Rm125 in on trade and was assured all it needed was a coil. The boy ...
Old 01-15-2009, 10:50 AM
Last Online: 01-15-2009 10:55 AM
Default 96 RM125 won't start
I recently took a 96 Rm125 in on trade and was assured all it needed was a coil. The boy said it had a fresh top end job. He said while he was riding one day it died. He said Suzuki looked at it and it needed a coil. Of course I put a coil on and still no spark. After that I put a new stator on and now it has a strong spark but still refuses to start. I even sprayed a little starter fluid in it, yes I know better but it didn''t start anyway. I don''t get it. I have fuel, I have fire, what don''t I have? Timing? I haven''t used a comp. tester, but comp. feels good.
Old 01-22-2009, 11:09 AM
Last Online: 01-29-2009 11:56 AM
Might sounds dumb, but make sure the plug wire is all the way down. ( figured id start with a simple idea). i have left it up and gotten pissed cause it wont start... then i check the plug wire. good luck.
Old 01-22-2009, 11:40 AM
Last Online: 01-22-2009 11:40 AM
START BY PULLING THE PLUG OUT AND PUT YOUR FINGER OVER THE PLUG HOLE. WHEN YOU GO TO KICK START THE PRESSURE SHOULD BLOW YOUR FINGER OFF THE HOLE. IF NOT YOU HAVE A COMPRESSION PROBLEM. NEXT IF YOU HAVE A CHOKE PULL THE CHOKE AND TRY TO START WITHOUT GIVING IT ANY FUEL. HOPE THIS CAN HELP. GOOD LUCK
Old 01-22-2009, 12:28 PM
Ripped78's Avatar
Last Online: 10-06-2009 02:36 PM
Have you tried push starting it?
Old 01-22-2009, 12:50 PM
92rm125's Avatar
I do my own stunts!
Last Online: 04-13-2009 02:27 PM
Yeah, give bump starting it a go. Try second gear, first may be a little low.
Other that I'm at a loss. You say there is spark, fuel... Oooo, is it the RIGHT spark plug? Just because you are getting spark, it may be a very weak one.
Old 01-27-2009, 12:09 PM
haha, keeping with the simple ideas, is the plug wet? lot of buildup? if it is clean it or better yet get a new plug.
Old 04-12-2009, 03:22 PM
Last Online: 04-12-2009 03:22 PM
What ended up being the problem? I'm having the same issue with my 98 rm125.
Old 05-28-2009, 09:51 PM
2 stroke dirt's Avatar
Last Online: 07-11-2009 03:20 PM
Try checking your carb it might have some dirt in it.... that is if you've tryed everything else... as far as timing goes with 2 strokes its not something you need to worry about due to the fact that the fuel goes in the top end from the pressure caused by the downward motion of the piston... good luck.. hope you figure it out if you haven't already
Tags
rm125
Similar Threads for: 96 RM125 won't start
01 RM125 TANK FIT ON A 99 RM125?? rm-mulisha 2-Stroke Motorcycles - Suzuki 2 03-03-2009 07:31 PM
Won't Kick Start But Will Bump Start RoostRM125 2-Stroke Motorcycles - General Discussion 38 02-22-2008 06:06 PM
Will a cyl from an 01 RM125 work on a 98 RM125? MSGHUFF 2-Stroke Motorcycles - Suzuki 4 06-26-2007 12:30 AM
04 RM125 krebstaz 2-Stroke Motorcycles - Suzuki 2 05-08-2007 04:12 PM
My 93 Rm125 03grandam Photo & Video 4 04-22-2007 09:40 PM
