95 rm125 HELPThis is a discussion on 95 rm125 HELP within the 2-Stroke Motorcycles - Suzuki forum, part of the 2-Stroke Motorcycle Forums category; have a 95 rm ran great for ever, recently started having problems kicking. When I try to kick it over ... |
| have a 95 rm ran great for ever, recently started having problems kicking. When I try to kick it over every kicks or so it blows a huge gust of air out of the exhaust. I have no idea as to why, can someone please help. Keep in mind it rode great one day and the next wouldnt run at all |
| Try the basics first: air, fuel and fire. Make sure your air filter isn't clogged, you have fuel reaching the cylinder and check that your plug is creating an adequate spark & isn't fouled. |
| Did all the above, took my cylinder off and I noticed the piston ring has worn down un-even could this the problem. Also I havent checked the reeds yet |
| lol you need a rebuild. if your rings are worn down un evenly. better get your bottom bearing done and trued. new rings. new piston aswell. new rod. and topend gasket kit. ---------- Post added at 09:56 PM ---------- Previous post was at 09:54 PM ---------- a bottom end bearing is probably the most painful to the pocket, job to do to a bike lol looking at around 300 bucks. depending on your country. but good luck.. dont try starting your bike !! get a rebuild |
| 01 RM125 TANK FIT ON A 99 RM125?? | rm-mulisha | 2-Stroke Motorcycles - Suzuki | 2 | 03-03-2009 07:31 PM |
| 96 rm125 | CR125"90" | 2-Stroke Motorcycles - Suzuki | 1 | 08-26-2008 09:44 AM |
| rm125 help | Blades | 2-Stroke Motorcycles - Suzuki | 0 | 01-07-2008 09:03 PM |
| ever had a 86 rm125? | tj0llll0 | 2-Stroke Motorcycles - Suzuki | 4 | 11-14-2007 01:39 AM |
| Will a cyl from an 01 RM125 work on a 98 RM125? | MSGHUFF | 2-Stroke Motorcycles - Suzuki | 4 | 06-26-2007 12:30 AM |
