94 rm 125 won't idle, please help
This is a discussion on 94 rm 125 won't idle, please help within the 2-Stroke Motorcycles - Suzuki forum, part of the 2-Stroke Motorcycle Forums category; So i picked up this bike and it runs good but it doesn't idle. i know a little bit about ...
Old 09-13-2008, 10:53 PM
Last Online: 03-18-2009 07:51 PM
Default 94 rm 125 won't idle, please help
So i picked up this bike and it runs good but it doesn't idle. i know a little bit about bikes so i look for the idle screw on the carb and its not there. now is it normal for my bike to run ok without this screw and just the hole empty on the car? and i ordered the part from my local shop, when i screw it in and i have my bike running the bike should eventually idle as i adjust the screw right? what if it don't idle, whats next? thanks
Old 09-13-2008, 11:13 PM
I've been RM-Zedded
You will hear many guys say 2-strokes never idle, and if they do, it's not for very long. However, if you are good at jetting you can get them to idle, but sometimes it's more work than it's worth -- Your call.
The bike should still run just fine, because all the idle screw does is open the throttle a little bit to give it more gas (the same as you holding the throttle open). Yes, you should be able to simply install the new screw and hopefully it idles.
I read all the time about 2-strokes that do idle and others that don't. I've never owned one, but the ones I've ridden usually idle at least for a little while.
Old 09-15-2008, 09:46 PM
ThePipe's Avatar
Last Online: Today 12:44 AM
Don't sweat the idle
Old 09-16-2008, 01:03 AM
Freak's Avatar
Hook 'Em
Last Online: Yesterday 08:16 PM
from my exp, woody is right. Some will, some won't. I had a TM 400 zuke that would never idle. My CR500 would sit there and idle all day long.My jetting was right on the money with the 500 thou. god I miss that bike!
Old 09-18-2008, 05:30 PM
hey i got the right idle screw in but i have no idea where to begin. i would assume screw it in til its somewhere in the middle and then both ways but i am probably wrong. what do i do i can't take my hand off the gas for a split second and i hate it.
Old 09-19-2008, 08:22 AM
VAL's Avatar
VAL VAL is offline
Get your motor runnin
Last Online: Yesterday 09:05 AM
Screw in the idle screw until you can take your hand off the throttle. Then adjust your air screw until the idle increase some more, then back off a little on the idle screw. Work between the two until you get to your desired idle.
Old 09-28-2008, 12:26 AM
Last Online: 02-15-2009 12:49 PM
just keep tightening the idle screw until your idle starts going up. dont run it until you get the screw, the slide is very vulnerable to getting scratched with a hole in the carb for dirt to get through
your bike may not idle however, as your compression gets lower, your bike will need more fuel in order to idle. eventually, you cant idle any longer, and by then its time for a new top end
same bike btw
Old 11-25-2008, 11:10 AM
92rm125's Avatar
I do my own stunts!
Last Online: 04-13-2009 01:27 PM
It is a myth the 2 stroke won't idle. Of course they will.. Why give them an idle screw??! Lol
It is just a matter of jetting the bike correctly for you alltitude and conditions. And having the correct adjustment on the air screw.
Similar Threads for: 94 rm 125 won't idle, please help
98, Cr 250 idle, HELP!!! 80stars 2-Stroke Motorcycles - Honda 17 06-26-2007 07:16 PM
JR 50 Idle tjtibb 2-Stroke Motorcycles - Suzuki 1 12-01-2006 07:39 PM
125 idle WhiskeyThrottle 2-Stroke Motorcycles - General Discussion 7 09-21-2004 10:53 PM
idle p8nt 2-Stroke Motorcycles - General Discussion 4 05-15-2004 07:01 PM
Won't Idle Keetoman393 4-Stroke Motorcycles - Honda 2 12-28-2002 09:36 PM
