88 rm250 running backwards?!This is a discussion on 88 rm250 running backwards?! within the 2-Stroke Motorcycles - Suzuki forum, part of the 2-Stroke Motorcycle Forums category; Ive got a 1988 rm250 that is pretty cherry except i think the stator is bad. Fresh top end, fresh ... |
| Ive got a 1988 rm250 that is pretty cherry except i think the stator is bad. Fresh top end, fresh carb, yada-yada but the engine deffinitly fires back the wrong direction and it isnt the kickstarter. It was a big surprise to take off in reverse |
| Your timing is off, check the stator and make sure the key is in the flywheel and is not stripped. |
| I had an old 250 Husky that would do that. It was always quite a surprise to blast off in reverse, roost hitting the back of my legs. Them was the days. It is just like Spikester says, your timing is two far advanced causing the bike to run backwards. Two strokes don't have a cam so they don't care which way they run, it is all up to timing. If you ever had a .049 control line plane as a kid that would start backwards, it is just like that. The stator is probably good, just needs to be rotated a little. |
BINGO! You're timing is to close to Top dead center! Pull the rotor & put in a new key, clean the rotor & stator. Re-time to the correct setting per the manual, you should be good to go from there! |
| Tags |
| rm250 |
| backwards endo | klxrider3214 | General Discussion | 13 | 10-23-2005 10:03 PM |
| Jetting: - 03 RM250 running rich | TNTRM856 | 2-Stroke Motorcycles - Suzuki | 6 | 03-29-2005 05:52 AM |
| My bike runs backwards!!! | swifty | Vintage Riding | 2 | 10-20-2004 11:12 PM |
| My bike runs backwards!?!?! | swifty | 2-Stroke Motorcycles - General Discussion | 16 | 10-13-2004 07:33 AM |
| Think about it : Your favorite track. backwards | Z-Man 393 | General Discussion | 4 | 05-17-2004 07:35 PM |
