2004 RM250 with no spark
This is a discussion on 2004 RM250 with no spark within the 2-Stroke Motorcycles - Suzuki forum, part of the 2-Stroke Motorcycle Forums category; Evening all, My son bought a mint 04' 250 from his buddy who dropped the bike in a water hole ...
Old 10-08-2009, 08:22 PM
Last Online: 11-10-2009 06:42 PM
Default 2004 RM250 with no spark
Evening all,
My son bought a mint 04' 250 from his buddy who dropped the bike in a water hole and hydro-locked it. Put the bike up for a couple months without emptying it and cleaning and it seized the bottom end. We bought it. I split it. Put a Hot Rod crank in it. New bearings, seals and a top end. The motor is brand new basically. Put it all back together again. Kicked it to break it in and NO SPARK. Coil resistance readings are dead on perfect. Continuity of all wires is good. All grounds are good. Checked the stator voltages according to the factory service manual at the big connector to the CDI. I am supposed to get 25V or more across two pins. I barely get one volt. I am supposed to get 2V or more across the other two pins. I barely get .1 V. This voltage test alone tells me the stator is bad. But to be sure I checked the resistance across two pins of the large plug going to the CDI where the manual says I should get 78-122 ohms. I get 96. Thats good. The other two pins I measure, the book says I should get 28-46 ohms. I get an open circuit. That tells me bad stator again. My question is this. I check for 200V or more to the coil from the stator I think is where it is coming from. I get like somewhere between 5 and 10 volts I think. DEFINITELY not 200V. The service manual says to use a Peak voltage adapter inline with my multi-meter when I am checking for voltage checks when I kick the bike over. I did not have a peak voltage adapter. What does that adapter do? Does it just keep the highest reading dispalyed on my meter? Could it effect my readings? If my stator is bad, which I'm thinking it is, where can I get a good aftermarket stator for my 04' RM.
Thanks all for helping me help my son.
Have a good night.
Sid
Old 10-22-2009, 05:58 PM
Last Online: 10-22-2009 06:07 PM
WE HAD A PROBLEM SIMILAR TO THIS AND HAD THE STATOR RE-WORKED WHICH DIDNT COST MUCH WE PAID £68 STERLING TO HAVE THIS DONE .
GOT IT BACK REFITTED AND HAVENT LOOKED BACK AS GOOD AS NEW ONE .
HOPE THIS HELPS PETE
Similar Threads for: 2004 RM250 with no spark
For Trade- 2004 Suzuki RM250 ccra92 Motorcycles & ATV's 2 07-24-2008 05:54 PM
Silencer or spark arrestor '87 or '88 RM250 artistic_gore Wanted Items 0 05-07-2007 02:58 PM
2004 RM250 OFF ROAD JETTING? ACDSRM 2-Stroke Motorcycles - Suzuki 3 09-26-2005 01:32 PM
NEW 2004 RM250 MISSING AT 3/4 THROTTLE ? ACDSRM 2-Stroke Motorcycles - Suzuki 3 07-11-2005 03:06 AM
what would be the best pipe for a 2003-2004 rm250 travis smith 2-Stroke Motorcycles - Suzuki 8 06-15-2005 01:00 AM
