1999 rm125 bogsThis is a discussion on 1999 rm125 bogs within the 2-Stroke Motorcycles - Suzuki forum, part of the 2-Stroke Motorcycle Forums category; Hey guts I'm new here and am having a bit of trouble with my bike, it's a 1999 rm125 the ... |
| Hey guts I'm new here and am having a bit of trouble with my bike, it's a 1999 rm125 the compressons right at 120 which I know is a bit low, but it starts 1st or 2nd kick almost every time, has great mid and high end power and idols smooth. However when in a slow roll about 2 mph and you gunn it, it boggs down for a sec then takes off like a bat out of hell. It seems like it may just be running rich, I've played with the airscrew and it helped a bit but not much. Just wondering what u guys thought. Also I just cleaned the carb and cleaned all the jets. Thanks, Mike |
| The airscrew will fine tune the pilot circuit for off-idle performance but it only does so much. If your screw is out from seat more than maybe 2.5 turns, you need a smaller jet. If your screw is out from seat less than maybe 1.5 turns, you need a larger pilot jet. The needle position has a minor affect in the lower RPM but it's more for the mid range transition, so your pilot jet is what needs to be altered based on what you describe. Scott |
| Awsome! Thanks for the info! I have a 165 jet I'll through in and see if that helps, do you think this will be to small? |
| 99 cr250 bogs down | thor2mx | 2-Stroke Motorcycles - Honda | 1 | 07-05-2009 09:03 PM |
| 06 yz250f bogs down.. any ideas? | rolloutjg | 4-Stroke Motorcycles - General Discussion | 13 | 06-10-2009 02:42 AM |
| yz250 bogs instead of powerband | Ryan#53 | 2-Stroke Motorcycles - Yamaha | 5 | 08-11-2008 07:32 PM |
| engine bogs and dies | Viggey | 2-Stroke Motorcycles - Suzuki | 2 | 06-02-2006 02:46 PM |
| 1999 Suzuki RM125 | jhux | Motorcycles & ATV's | 3 | 09-18-2003 08:22 AM |
