Old 10-17-2014, 10:05 AM
Last Online: 10-17-2014 01:22 PM
Question 1998 rm125 bog issue
So I have had my rm125 for about a year now and have always had a issue going up hills like really small hills too, the problem is when I get about halfway up the hill I bog out but if I pop clutch it's starts to go then bogs again
Old 10-17-2014, 10:31 AM
gusco's Avatar
Last Online: 06-16-2019 09:51 PM
Have you checked your float height?
Old 10-17-2014, 11:11 AM
Wha should it be set at
Old 10-17-2014, 11:57 AM
gusco's Avatar
Check your manual or wait for someone with your same bike (or that manual) to chime in. Meanwhile, you could check your compression, exhaust packing, and plug. Once you get the float and things mentioned right then you can move on to getting. Oh! And check your air filter.
Old 10-17-2014, 12:01 PM
thanks for your help, have done evrything you said already except check float
Old 10-17-2014, 12:22 PM
gusco's Avatar
Alrighty! There's also a thread on here about how to build a leak down tester for around $20, in case it is a right side crank seal or some other sort of leak that is coming into effect under full load.
Similar Threads for: 1998 rm125 bog issue
1998 rm125 brabon General Discussion 10 12-06-2013 08:21 AM
Wierd issue 1998 rm 125 pvmick 2-Stroke Dirt Bikes - Suzuki 5 08-08-2012 11:11 PM
1998 RM125 UP-Rider 2-Stroke Dirt Bikes - Suzuki 2 08-08-2012 10:44 PM
1998 RM125 UP-Rider Dirt Bike Riding Tips 3 07-30-2012 03:38 PM
1993 RM125 Coolant/Oil issue robxfinch 2-Stroke Dirt Bikes - Suzuki 0 07-12-2010 08:13 AM
