Old 01-29-2018, 02:38 PM
2trebel's Avatar
Last Online: 04-04-2018 07:30 PM
Question 1997 RM250 Fuel dripping down cylinder
So I recently bought a 1997 RM250 for pretty cheap, the guy claimed it had a top to bottom rebuild. From what I can see the bottom looks to be done, but not the top.
Compression is good but I looked down the spark plug hole and see alot of carbon buildup on the top of the piston.
Anyway, the bike is extremely hard to start, cleaned the carb, checked the reeds, I have fuel and spark and this is the only thing I think it could be. I will provide a picture of what I mean but when i took the intake and reeds off and looked in the intake, I could see fuel dripping down the sides of the cylinder. Could it be blown rings/ old piston? I'm out of ideas..
Picture of the fuel dripping: https://imgur.com/a/xWF89
Thanks
Old 02-09-2018, 08:49 PM
Age is a state of Mind
That's interesting. I honestly don't know if that's good, but it does appear to have too much oil / gas in there.
It does run though?
Old 02-13-2018, 09:51 AM
Last Online: 02-14-2019 10:37 AM
I don't think that much fuel in the cylinder is normal, it's probably flooded. Did you leave it parked with the fuel tap turned on?
Here's what I'd suggest- drain the tank and carb, clean out the carb one more time.
Remove the spark plug and kick the engine over 10-12 times.
If the plug is black, wet, or cruddy looking replace it.
Reinstall plug
Mix up fresh fuel
Pour a little fuel into the tank, then try to start it. If you kick for a while and start to smell fuel, it's flooding and you'll need to sort out if the issue is in the carb or somewhere else. My guess is that due to the fuel in the cylinder, the plug is wet or fouled and if the fuel was left on while the bike was sitting you may have fuel getting into the cases.
Old 03-04-2018, 01:13 AM
Can't a float being set incorrectly cause this exact thing too? it can allow the bowl to fill up to the point that it will drain into the engine.
Seems like I remember something like that.
Old 03-04-2018, 06:34 AM
Last Online: Today 09:11 AM
Default correct
THat is correct and a leaking float valve can do the same thing.
Similar Threads for: 1997 RM250 Fuel dripping down cylinder
1997 rm 125 cylinder sleeve brabon 2-Stroke Dirt Bikes - Suzuki 3 02-19-2014 11:44 AM
1997 Suzuki RM250 Hghlndr Classified Ads 7 02-17-2010 04:12 PM
1997 RM250 no idle stillife9796 2-Stroke Dirt Bikes - Suzuki 3 05-08-2007 07:04 PM
1997 RM250 clutch slipping. Ekholm 2-Stroke Dirt Bikes - Suzuki 11 09-10-2006 09:51 AM
1997 RM250 Jetting for High Altitude forloan 2-Stroke Dirt Bikes - Suzuki 1 07-01-2005 10:02 PM
