Whats the cause?
This is a discussion on Whats the cause? within the 2-Stroke Motorcycles - Kawasaki forum, part of the 2-Stroke Motorcycle Forums category; I started my bike(2002 KX100) up for the first time in like 2 weeks. It took atleast 20 kicks and ...
Old 02-06-2006, 12:23 PM
CowAsocky's Avatar
Last Online: 02-14-2009 03:49 PM
Default Whats the cause?
I started my bike(2002 KX100) up for the first time in like 2 weeks. It took atleast 20 kicks and has never taken this long. The weather was really cold at like 40 degrees and real windy. Once I got it started I let it warm up for a couple minutes on choke, took it off and it would die off, turned choke back on (did this like 8 times). Then I tried to ride without choke really quick and try and get her moving but it bogged. Tried again and I got her into the beginning of second gear and it bogged and sputtered 3 times, pulled the clutch in and got the choke on real quick. In the end I finally got her to run without choke with very few small bogs throughout the day. From then on she rode with a little feeling of loss of power, but I was mud(creek) riding so I'm sure that played a factor.
What could be the problem? Just the cold weather? It being not started in 2 weeks? New top end time? Air leak?
Thanks, sorry for the long write up. :
Old 02-06-2006, 01:20 PM
kx_rider53's Avatar
2 stroker
Last Online: 09-15-2009 12:02 PM
Default Re: Whats the cause?
Well you should never really let in warm up on choke. You should use the choke to start it when it needs it, which is usually when the bike hasnt been ridden in a while. It should only be on for ten to fifteen seconds. It sounds like your bike is not getting enough fuel because the choke blocks the air from entering the fuel air mixture which you said you had to use to keep it going. So i think you can rule out a air leak, maybe your float? Others will offer more information.
Old 02-06-2006, 03:06 PM
Crogg's Avatar
RHC YZ504 Rocket
Last Online: 02-11-2010 09:12 PM
I would check you carb vent tubes for blockage and then check for a plugged pilot jet!
Old 02-07-2006, 06:12 PM
kdxrider's Avatar
Last Online: 04-07-2008 05:15 PM
I'm definately no expert but sounds like your carb is plugged with something try cleaning it out real good & go from there
Old 02-07-2006, 07:17 PM
psycho393's Avatar
I got DUALS
Last Online: Today 01:09 PM
Rings.
Old 02-07-2006, 08:05 PM
MotoMojo17's Avatar
Pinger-Slinger
Last Online: 09-04-2009 11:37 AM
+1, rings.
Old 02-07-2006, 08:16 PM
Crazy's Avatar
Accident Prone
Last Online: 12-29-2009 11:11 AM
I also think its either a plugged carb pilot. Make sure you check your air filter too. We had one with symptoms like this once and the filter was covered in mud.
Old 02-09-2006, 04:52 PM
CowAsocky's Avatar
Well, i just talked with my local mechanic and he said to take the carb out and drain it and make sure no grit is in there cloggin the stuff up. He also said to drain some of the gas out of the petcock into a bottle and check it out. He said water might have gotten in the airboot and was making me have to blow it out. So im gonna take the carb out, drain it and inspect it, drain the gas a bit and change the spark plug, and make sure the air filter isnt damp.
One question, after i drain the carb and put it back in, do i turn the gas on and give it a little throttle to fill it back up before i start the bike?
-Thanks
Old 02-09-2006, 06:24 PM
Semper Fidelis
All you have to do is turn the petcock on, the float bowl will fill until the float needle closes off the fill circuit. Not a pumper type carb on your KX 100, anyway, without a 4-T type accelerator pump (Keihin FCR or Edelbrock Quicksilver) carburetor it wont squirt fuel into the cylinder.
Bill
Old 02-09-2006, 06:36 PM
Silver_Fox's Avatar
Wut the?
Last Online: Today 10:24 AM
Originally Posted by psycho393
Rings.
Yep, sounds like it. I had a RM125 with the same symptoms. I took it apart and found the rings had seized and scored the cylinder. Play with the carb if you like, but while the carb is off shine a light in the intake port and do the same on the exhaust side to see what the piston / rings look like.
Old 02-10-2006, 01:00 PM
CowAsocky's Avatar
I got the carb half way out, and found that the two top screws were stripped and i dont have enough tools to get ahold of em . Anyways, i got a look in the back of the carb from the airboot. It had a good bit of grit all over the place and on the piston/slide and the two holes closest to the edge were clogged a bit. So im taking the bike to my local mechanic and let him fix her up.
Similar Threads for: Whats the cause?
Whats your BIG air? mxmama393 General Discussion 53 12-25-2008 09:23 PM
Whats next? MONSTER450 General Discussion 2 06-07-2007 11:23 AM
whats up diesel71805 Member Introductions 3 04-26-2007 12:04 PM
Whats better? Mobius ATV/UTV - Honda 17 11-09-2004 06:05 PM
whats better xr 250, klx 300, drz 250, Newf_Rider 4-Stroke Motorcycles - Honda 11 04-27-2004 02:47 PM
