Update on my 250
This is a discussion on Update on my 250 within the 2-Stroke Motorcycles - Kawasaki forum, part of the 2-Stroke Motorcycle Forums category; Yesterday I got the sub frame off, and the air box out, got the seat cover, brackets, and foam off ...
Old 03-25-2005, 06:55 PM
iceman's Avatar
Last Online: 11-05-2005 10:55 AM
Default Update on my 250
Yesterday I got the sub frame off, and the air box out, got the seat cover, brackets, and foam off the seat, and all the guards ready for making pretty. Today it took me about 3 hours to clean the air box boot and airbox. I totally dissasembled it and cleaned it. I also spray painted it, and now it looks like turd, so I'll have to figure that out. I tried to get the linkage rods off, but the bolts are too tight, what should I do to loosen them up? I tried wd40 and heating them. They are starting to strip too. I was going to look for a adapter for my impact driver so it could use sockets. Would that work?
Old 03-27-2005, 11:29 AM
1989kx125's Avatar
Last Online: 03-04-2006 11:35 AM
Default Re: Update on my 250
why do you need to take them off. i took them off on my kx when i overhauled it and it was such a pain putting it back together
Old 03-27-2005, 12:17 PM
iceman's Avatar
I need to get the shock off, and they are in the way of the bottom bolt. I put liquid wrench on last night and have been using an impact driver on them, they won't budge. Should I put a flame on the threads to heat it up? It is a little cold outside. Or should I go get a big torque wrench for more leverage, I need one anyways.
Old 03-27-2005, 12:19 PM
1989kx125's Avatar
i dont know what to tell you. put the impact on the other side, the bolt could be frozen inside the linkage and maybe the nut will move. hope this helps
Old 03-27-2005, 12:27 PM
iceman's Avatar
I've been trying that, I think I just need to keep working it. I go back and forth between sides, to try and loosen both ends up, but tis not been working, so I'm taking a break.
Old 03-27-2005, 12:31 PM
1989kx125's Avatar
does it look like it could be frozen. or someone went a little crazy with red locktite
Old 03-27-2005, 12:36 PM
iceman's Avatar
Well, it hasnt been taken off for 11 years, so thats part of it, I dont see any loctite on the threads, so in a little bit I'm just gonna go back and keep trying. I'm just surprised the impact driver didnt get it right off, it has gotten everything else off I needed. Its also hard to get the wrench in there because the chain is on and its kinda tight.
Old 03-27-2005, 12:50 PM
1989kx125's Avatar
id take the wheel off. dont let your rear brake lever get pushed all. its not fun to push the piston back in. it must have not be greased or something becuase my 15 year old 89 didn't give me as much trouble as yours.
Old 03-27-2005, 06:21 PM
iceman's Avatar
Ugh, I tried heating it. It gave me a nasty burn it was so hot, so I decided to let it cool a bit and then try. Still wont budge. I'm lost here. I ordered a free brochure from Kroil that has 100 tips for removing stuck, frozen and rusted bolts. So when that gets here I'll try everything. I don't understand how something can be so tight.
Old 03-27-2005, 06:27 PM
YzRacer#53's Avatar
Last Online: 02-15-2006 08:13 PM
What exactly are you attemptin to do?
Old 03-27-2005, 07:20 PM
iceman's Avatar
Get the linkage rods off.
Old 03-27-2005, 10:48 PM
kawamaha's Avatar
Last Online: 05-07-2009 05:31 AM
Did you ever try an Air Impact Wrench? I think you must hit the bolts. first with a hammer on a socket, then with the Air Impact Wrench. must work!?
Old 03-27-2005, 10:56 PM
quadfather03's Avatar
Last Online: 01-18-2010 05:28 PM
did you heat the bolt or around the bolt? Do you have the bike far enough off the ground that the tire is not touching? there is some major pressure on those things is the top of your shock disconnected if not that will relieve some pressure.
Old 03-28-2005, 03:14 PM
iceman's Avatar
I don't have an air impact wrench, I heated around the threads and head and everywhere. The tire is off the ground, the top bolt for the shock is taken out. It leaked rain in our garage and there is a puddle all around my bike, and I have no room to work on it, so I cant do anything today, but when the puddle is gone I will be back out there trying to get it off again. I have like a 3 by 5 foot work area, it is super cramped, that doesnt help at all. This is crazy that it is so tight! Thanks for all the suggestions though, maybe I'll try to get an air impact wrench.
Old 03-28-2005, 08:21 PM
iceman's Avatar
Does anyone know if the Ceet complete seat would fit my bike, it says 99-02, I have a clymers and it ranges from 92-00 I believe, so technically wouldnt the parts have stayed the same through those years somewhat? The places where my mounting brackets go on the plastic are all busted up.
Old 04-06-2005, 12:36 AM
iceman's Avatar
Nobody knows?
Similar Threads for: Update on my 250
MMI update? Henry General Discussion 48 04-09-2007 10:27 PM
UPDATE!!! TRXman86 ATV/UTV - Yamaha 15 04-22-2004 04:46 PM
Update Racer#857 General Discussion 8 11-08-2003 07:52 PM
