Old 02-08-2018, 11:07 AM
Last Online: 08-27-2018 12:51 PM
Default Stripped shift lever pedal
Looking for a quick fix to this problem Iíve tried taping the threads to maybe help the teeth get a better grip, Iíve tried aluminum strips thinking it would work and it does for all of about 2 minutes. Thought about drilling a small hole between the shift shaft and lever and inserting a little bar or bolt and spot welding. Also thought about job weld and also solder. Anybody have a better solution? Itís a 99 kx 60
Old 02-08-2018, 11:14 AM
Last Online: Today 03:33 PM
Replace the lever.
Old 02-10-2018, 02:30 PM
schwen_108's Avatar
Last Online: 03-06-2019 03:09 PM
Originally Posted by PawPaw View Post
Replace the lever.
I second this. If you're going to do any modification, be sure to do it to the shift lever only. You don't want to go messing with that shift shaft and end up needing to replace it. Especially on a bike from 1999. Parts are getting harder and harder to find for bikes like that.
Similar Threads for: Stripped shift lever pedal
Rear Brake Lever/Pedal adjustment - reshape??? WERNER1 2-Stroke Dirt Bikes - Honda 14 09-26-2012 07:48 PM
SHIFT PEDAL cr125r 2-Stroke Dirt Bikes - Honda 1 12-24-2008 10:56 AM
05' YZ 250 shift lever? 05YZ250 2-Stroke Dirt Bikes - Yamaha 3 09-28-2007 08:03 AM
shift pedal tdc1107 2-Stroke Dirt Bikes - Yamaha 10 01-20-2007 09:33 PM
quick fix for a shift lever??? 1kx100 General Discussion 10 01-24-2006 07:21 PM
