Old 11-21-2019, 02:05 PM
Last Online: 01-26-2020 06:10 PM
Default Stater Problem on 1992 Kx80 engine
Can any one recommend were I can get ever a new stater or if I can get my old one refubish. It's for a 1992 Kawasaki kx80. As I'm having trouble finding one. Well the best place to find out is from you lot with all your connections.
Many thanks.
Old 11-22-2019, 12:47 AM
Last Online: 06-28-2020 05:10 PM
How do you know it needs replacement?
Old 11-22-2019, 12:05 PM
When the engine gets hot it cuts out then as soon as its cooled down it starts.
Old 11-22-2019, 02:30 PM
schwen_108's Avatar
Retired from offroad
Last Online: 11-22-2019 02:42 PM
https://ricksmotorsportelectrics.com...Stator-20_K155
Old 11-22-2019, 03:28 PM
Is there any were in the UK.
Old 11-22-2019, 04:42 PM
Last Online: Today 07:30 AM
Before replacing the stator... I would suggest that you do an ohms test of the ignition coil on both the primary and the secondary sides. 90% of the time when the engine stops when hot and then restarts when cooled down are ignition coil issues. The primary ohms reading is normally too low. This then allows the coil to break down under heat and then no spark. Also if the secondary side reading is too high it can also loose spark when the engine gets warm.
This is not to say that the stator can't do this as it too break down under heat, but most of the time if the stator is bad it just will not start at all.
I have seen many stators replaced only to find out that the issue was the ignition coil. Ignition coils fail more often than stators.
Old 11-23-2019, 01:01 AM
Hi paw paw
I replaced the ignition coil about a week ago. And still cuts out when hot and starts back up when cool.
Similar Threads for: Stater Problem on 1992 Kx80 engine
1992 kx80 Seberry99 Dirt Bike Restorations and Builds 1 11-21-2014 05:44 PM
80s kx80 engine and frame are different years! calebnc302 2-Stroke Dirt Bike Forums 0 12-04-2013 11:20 PM
In NEED OF KX80 or 85 ENGINE!!! Catchmeifyoucan401 2-Stroke Dirt Bike Forums 0 01-05-2011 06:40 PM
KX80 HEAD GASKET PROBLEM! KX80RIDA 2-Stroke Dirt Bikes - Kawasaki 1 05-08-2009 07:21 AM
Looking for older kawasaki kx80 engine chrism1829 Classified Ads 0 04-30-2007 04:27 PM
