Old 12-15-2019, 11:43 AM
Last Online: 01-10-2020 03:51 PM
Default Running problems
Can anyone help I'm starting to get really angry with my 1997 Kawasaki kx100. Iv changed the coil, stator, air filter, clutch. But now its blowing plugs. The plug is clean when I take it out. Dose anyone have any ideas as to why and how I can fix this.
Old 12-15-2019, 01:06 PM
Last Online: Today 12:39 AM
Do you mean it is fouling the spark plug?
If so, then I would suggest that the bottom end is loaded up with excess fuel mix and is causing the plug to foul. You must remove the excess fuel mix. Turn off the gas, drain the carb of fuel, remove the spark plug, open the throttle wide open and then kick the engine over until no more fuel mix comes from the spark plug hole. Then put a new plug in, open the fuel flow, hold the throttle wide open and kick start it. It should run ( but keep it at high rpms) , but very rough until all the excess fuel is blown out.
Old 12-15-2019, 02:50 PM
Thank you Paw Paw I will give that a go. But if that dont work any ideas as to what i can try. Thank you
Old 12-15-2019, 10:56 PM
bjunior's Avatar
novice
Last Online: Today 02:34 AM
Read the plug it says a lot.
Old 12-16-2019, 09:19 AM
Last Online: 01-17-2020 11:02 AM
Make sure when you park the bike, even if it's for a few minutes, that you turn the fuel tap off as well.
Similar Threads for: Running problems
Running Problems Len1986 2-Stroke Dirt Bikes - Kawasaki 1 11-04-2019 08:56 AM
CRF150F running problems FallingOsh 4-Stroke Dirt Bikes - Honda 8 10-29-2008 09:34 PM
Cr 250 running problems please help!!! scouserdave 2-Stroke Dirt Bikes - Honda 27 07-13-2008 10:58 PM
yz250 running problems... Moto man26 2-Stroke Dirt Bike Forums 11 07-06-2008 10:48 PM
2001 KX 125 Running Problems.... 01KX125Ryder 2-Stroke Dirt Bikes - Kawasaki 10 03-02-2007 01:52 PM
