Old 07-31-2007, 07:39 PM
wFo250's Avatar
will fall over
Last Online: 01-08-2019 11:24 AM
Default No Flow?
Ko, I sold my '00 KX250 to my buddy, fresh complete rebuild.
PROBLEM IS when we poured the coolant into the rad, it wont suck it down!
Anybody know why this might be happening? The coolant does not appear to be flowing,
and the engine gets hot quickly.We took it back apart, and the impeller spins when kicked
over, and I blew in the line and it's unobstructed. Is there more to the pump
that I don't get>? I figure if the impeller is spinning, that's all you need to
move the fluid through.
Thanks in advance
Old 08-01-2007, 11:12 AM
Default Re: No Flow?
If you had a manual, it would tell you whether or not there was a screw that you need to use as an airbleed. That is pretty extreme that it won't circulate at all though. Many of us wouldn't have started it knowing that.
Old 08-01-2007, 11:17 AM
The Baron's Avatar
It sounds like you may have a huge air bubble or you may have the incorrect head gasket that's blocking a passage or one of the coolant passages is so corroded up that coolant isn't flowing.
Old 08-01-2007, 12:08 PM
dhighlan's Avatar
Last Online: 12-02-2008 10:00 AM
On these bikes there are 2 coolant dran plugs 1) on the water pump cover and 2) on the cylinder itself above the water pump half way up the cyinder. Take the hose off at the pump(frt hose) that comes from the right radiator and plug it so no water runs out. Take one plug out at a time and fill tap water through the fill hole until clean water comes out the drian plugs. If water runs out you know there is not a blockage in the head or cylinder.
The other thing is make sure the impeller nut is tightened properly to the shaft as it could slip if not tight.
Good Luck
Old 08-01-2007, 01:04 PM
I will just bet they had been wondering what those were.
Old 08-01-2007, 01:13 PM
dhighlan's Avatar
Oh Ossag..just trying to help
Old 08-01-2007, 01:17 PM
You did a good job.
Old 08-01-2007, 01:24 PM
dhighlan's Avatar
You did a good job.
Seems I am never quite sure if your rippin on me Ossage-Doesn't
Old 08-01-2007, 01:30 PM
I wasn't ripping on you.
Old 08-01-2007, 01:32 PM
dhighlan's Avatar
I know you weren't we have went through this before so I thought it was funny.
Old 08-01-2007, 01:37 PM
I like reading thoughtfull responses, even if I like to do something different.
Old 08-01-2007, 11:35 PM
wFo250's Avatar
will fall over
Thanks for the responses.
Bill, I still have my '01KX
The nut and impeller was in place, and I know it spins when kicked over.
I disconnected the hoses from the pump cover and blew air through, and the passage seems unobstructed, but I will try the plugs (I knew where ONE of them was)
Thanks again
--John
Old 08-02-2007, 07:58 AM
DRGSin393's Avatar
Last Online: 06-10-2014 01:42 PM
Alot of people feel that way! But trust me...Ive been around here long enough to see that if Ossa rips on you...youll know it!
Similar Threads for: No Flow?
High Flow radiators KKXR400R 2-Stroke Dirt Bikes - Honda 1 12-25-2006 09:57 PM
pro design air flow kit monstermatt ATV/UTV - Yamaha 4 07-20-2006 08:24 AM
Alba Pro Flow Kit Old Man ATV/UTV - Yamaha 30 03-01-2005 05:50 PM
High flow gas cans smithers General Discussion 15 08-06-2003 10:39 PM
Oil out of over flow/ Vent Hose? HLGuthery 393 4-Stroke Dirt Bikes - Yamaha 6 03-30-2003 05:31 PM
