New (to me) KX 125This is a discussion on New (to me) KX 125 within the 2-Stroke Motorcycles - Kawasaki forum, part of the 2-Stroke Motorcycle Forums category; I just bought a 1992 KX 125. It rides pretty good and starts one kick. It is my first 2 ... |
| I just bought a 1992 KX 125. It rides pretty good and starts one kick. It is my first 2 stroke bike, so I have a few questions. 1. What fluid do you guys recommend for the case? 2. Besides maintenance that you would do to any vehicle, is there anything specific to a 2 stroke that I need to be aware of? Thanks |
| Due to the high revving nature of a 125, buy yourself a compression tester. As for oil, you'll get more suggestions than stars in the sky. I'm of the belief you could run cooking oil in one if you changed it frequently. Any good motor oil will suffice, though. |
| I used to run premix that you get from a gas station in my 1983 cr 60 and my 1997 kx 100 and they lasted me a pretty long time so really any motor oil would work. |
| hey i have kx 125 93 my clutch basket is damaged but i can not find this parts in internet . plz help help |
| get your self some Bell ray gear oil FOR 2 STROKE'S!!! because you will mess up your clutch and gearbox if you use normal car oil because it has metal extracts in it |
| ok so ive got a 96 kx 125 and ive got a few problems.. every now and then (no method to its madness) it will just bog like its toatlly flooded.... pull in the clutch rapp it out and roll back into it and usually its fine.. ONLY happens when im starting off... also my powervalve cover leaks like a siv... what can i do to fix it? the motor has maybe 15 rides on it... been leaking since the rebuild.... |
you should just re-place the gasket by your power valve and it will stop leaking |
jetting i was told is spot on. nice carmelish color and ive never fouled a plug. and im new to riding dirtbikes.. |
| Bro, Get ahold of Freak on this site,he's from up your way an a heck of a wrencher He will help ......Good Luck......Jerry |
