Old 12-04-2017, 10:29 AM
Last Online: 01-16-2018 02:35 PM
Default KX85 Transmission
Hi,
I just finished replacing the crankshaft on my son's 2002 KX85. everything seemed to go OK when putting it back together. The gears turned OK, Shift forks seemed to move fine, the case went back in OK and everything. When I tried to test it with the engine on the bike, it shifted to neutral and it got stuck there and doesn't shift to any gears. I appreciate any information on what typically goes wrong or if you have any suggestions.
Old 12-04-2017, 07:33 PM
Check the shifting mechanicals behind the clutch as that is the normal place for these issues. Also check the shift lever shaft to make sure it did not push off the spring and arm under the clutch.
Old 12-05-2017, 05:04 PM
I removed the clutch basket and checked the mechanism. everything looks good. I think it shifts from 2nd gear to 5th and back but when in neutral then it stay there until I pup it back into 2nd with a screw driver by turning the shift star ( I think that is 2nd gear).
Old 12-06-2017, 08:18 AM
gusco's Avatar
Last Online: Today 11:19 AM
Try testing it while spinning the input shaft. I had a Blaster a couple days ago that wouldn't shift well until I put some spin on it, then it shifted fine.
Old 12-06-2017, 07:02 PM
Thanks for your reply gusco. yeah, I tried that too, but when in neutral, it still won't come out of it. It's like the shift lever's pawl stop reaching the pins to spin the shift drum's holder.
Similar Threads for: KX85 Transmission
kx85 issues Tncr80r Mini Dirt Bike Riders 5 05-28-2013 09:12 AM
kx85 shock oil Ryanl925 Dirt Bike Suspension Tuning 2 09-18-2012 07:09 PM
KX85 Help?? trailrider894 2-Stroke Dirt Bikes - Kawasaki 1 04-11-2011 09:49 AM
kx85 head? neodyman 2-Stroke Dirt Bikes - Kawasaki 0 12-16-2010 09:41 PM
HELP! 04 KX85 YZMOTO 2-Stroke Dirt Bikes - Kawasaki 22 06-02-2004 01:14 PM
