Old 09-30-2019, 03:08 AM
Last Online: 07-12-2020 12:17 PM
Default jetting misconceptions destroyed
What I have recently learned is that the main jet doesnít dominate the upper throttle openings - it works in conjunction with the needle (the distance between it and the needle jet) and also influences the idle jetting because some fuel is flowing up past the needle jet even when the throttle is only 1/8 open.
If you donít believe me then just put in a slightly skinnier needle and plug up the idle jet with silicone sealant or just stick a toothpick into its hole. Then you will see if the needle flow area isnít too far off then the bike will idle. The stock carburetors for motorized bicycles are that way. They donít even have an idle circuit.
Also I no longer consider using the needle clip position as the best means to adjust the mid range jetting. You can do it that way but then the off idle jetting suffers because the clip position controls when the needle taper comes into effect somewhere close to 1/4 slide open. The best way to change mid throttle jetting is to change the needle taper angle, not the clip position. This page fully explains: The Importance of Needle Height
This graph was derived from making jetting changes using my new jetting calculator which gives a more realistic version of each parts role in jetting:
www.dragonfly75.com/moto/images/jetrange.gif
Hereís my guide to carburetor tuning: 2 Stroke Carburetor Tuning
Similar Threads for: jetting misconceptions destroyed
rear wheel bearing cage destroyed and stuck 870 General Discussion 6 07-06-2017 11:33 PM
yfz gyt-r jetting kz13 ATV/UTV - Yamaha 1 03-07-2007 06:44 PM
NOR CALI TRACK DESTROYED! Pic yz250ftony Racing, Group Rides, Post Ride Reports 7 02-21-2006 07:14 PM
Misconceptions about insurance boogieonmyfinger General Discussion 5 01-06-2005 11:40 PM
misconceptions with new riders. Thump_This General Discussion 30 03-22-2004 10:21 PM
