Old 03-07-2008, 07:45 PM
Last Online: 09-10-2008 05:19 PM
Default ignition timing 94 kx 80
hey now-
i have a clymers book. it says i can advance, or retard the stator plate. would someone tell me what that will do? faster,slower,more botom,or top?
advance,retard,or justlet it be? oh it's a fresh motor top, and bottom
Old 03-08-2008, 04:11 PM
Last Online: 04-09-2008 05:35 AM
Default Re: ignition timing 94 kx 80
u useually only touch the timin if its not running right or if u have and kno how to use a timing light see the hole motor has to be in time with each other for the most hp gain u only mess with it if u think u kno how to time it better with the light and it dosent really make that much of a diff plus if u adv. it to far u risk a high chance of burning a hole in the piston if it works fine dont touch it if it dont and u have no idea how to time it and u suspect thats whats wrong send it to a local mechanic and get him to do im sure he will mostlikely be more then happy to do it for ya.
Old 03-09-2008, 07:40 AM
thank you, iwas just curious. bike runs just fine. butas usual i like to make thing go faster, without going boom!
Old 03-09-2008, 11:40 AM
dhighlan's Avatar
Huh what, Timing light on a kx80? What the.....are you talking about?
Old 03-09-2008, 11:47 AM
u can time any lbike electrical by using a timin light every motor has marks on the flywheel u use to time the stator and flywheel in sync for best pefformance u have to use a timing light to do this ive done it to my friends yz my tecate 4 and my friend did it to his kx250 and kx125 it draws the most power out of the bike.
Old 03-09-2008, 11:54 AM
dhighlan's Avatar
Mechanical explanation not "to find most power" explanation?
Old 03-09-2008, 01:58 PM
it changes when the sparkplug fires im means u can adjust the plug to fire right after tdc , before it which is bad,on tdc which burns holes in pistons,or a little bit further past tdc its all in the timiing if u time it right u burn all the gas in cylender more efficeintly which in turn creates more hoarsepower crisper throttle response and sometimes better mleage.
Old 03-09-2008, 02:19 PM
dhighlan's Avatar
You retard your timing to after TDC? Wow and you believe that makes the most power on a two stroke bike? So how many degrees do you retard it to ATDC? So on an 80 what degree would you advise have your transfer and exhaust ports with ATDC timing?
To my original question how do use your timing light, your procedure on a single cylinder two stroke bike?
Old 03-09-2008, 05:08 PM
im not at home now to tell u how to use it as i do not have my book it should tell u in any reapir manual for ur bike. i kno it tells u how in my book thats how me and my frineds all timed our bikes makes a big diff.
Old 03-09-2008, 05:27 PM
dhighlan's Avatar
Well when you get home and look in your book I would be real interested in what your "Book" has to say about using a timing gun.
Old 03-13-2008, 06:04 PM
yes crack that book open . more ponypower crisper throttle respones. telll me everything please?
Similar Threads for: ignition timing 94 kx 80
YZ2000 2-stroke Ignition Timing Problem davefordham 2-Stroke Dirt Bikes - Yamaha 7 12-02-2008 03:49 PM
Ignition timing.... 2001hondacr125 General Discussion 0 04-27-2008 06:58 PM
99 CR 250 IGNITION micro101 2-Stroke Dirt Bikes - Honda 0 06-22-2007 03:34 PM
FMF Ignition 99kx250rules General Discussion 7 06-12-2005 02:39 PM
FMF AOF Ignition Shocknut Product Reviews 4 09-25-2003 11:24 PM
