Help with timing!!!This is a discussion on Help with timing!!! within the 2-Stroke Motorcycles - Kawasaki forum, part of the 2-Stroke Motorcycle Forums category; I was wondering if anyone can tell me how to time a 1997 KX250? The 3 screws holding the stator ... |
| I was wondering if anyone can tell me how to time a 1997 KX250? The 3 screws holding the stator plate came loose and it was flopping around and started running bad. I need to know how to adjust it and tighten it back down in the right place. Thanks |
| Do you have the timing spec? If not, rotate the crank around until the piston is top dead center (TDC). There should be lines in the stator plate and one on the flywheel. Typically for Japanese two strokes the timing is identified as a distance before top dead center (BTDC) and a dial indicator can be used to determine exact timing but in this case, timing it TDC would get it running. So - run the piston TDC and look for a set of marks to align the stator to the flywheel. If you have a dial indicator, stab it into the spark plug hole and time it at maybe .8MM or 1MM BTDC. Scott |
| Thanks Scott!! That will help me ---------- Post added at 10:50 AM ---------- Previous post was at 09:28 AM ---------- I have been looking online to find a downloadable manual or just the timing specs (would love a download manual...can't find one). Do you know what they are? Thanks |
| YFZ to YZ timing cam mod | Dice Wiley | ATV/UTV - Yamaha | 18 | 07-06-2007 11:50 AM |
| yzf 400 cam timing | glen | 4-Stroke Motorcycles - Yamaha | 2 | 06-11-2007 07:50 PM |
| Cam timing? | Mopo | 4-Stroke Motorcycles - Yamaha | 27 | 06-11-2007 02:32 PM |
| TIMING | KRISGAMM | ATV/UTV - Yamaha | 4 | 07-20-2004 03:02 PM |
| timing? | Racer#857 | General Discussion | 4 | 01-03-2004 11:11 PM |
