Help! my forks are leaking.
This is a discussion on Help! my forks are leaking. within the 2-Stroke Motorcycles - Kawasaki forum, part of the 2-Stroke Motorcycle Forums category; My forks are leaking, how hard is it to fix? Should I try to do it myself?...
Old 12-04-2003, 11:26 PM
brokenbone's Avatar
Last Online: 01-26-2004 10:44 AM
flasher Help! my forks are leaking.
Old 12-04-2003, 11:27 PM
brokenbone's Avatar
Default Re: Help! my forks are leaking.
I have a 2001 KX250
Old 12-05-2003, 12:57 AM
Pull the dust seal down and use a business card or film negative to clean out between the oil seal and the fork tube- sometimes dirt gets jammed in there and makes the seals leak, but it's easy to fix.
Old 12-05-2003, 05:50 AM
Yardpro393's Avatar
393 race team
try what cowboy said first. if that won't do it your seald need replacing
Old 12-05-2003, 05:28 PM
RedFan's Avatar
Last Online: 08-29-2005 05:23 PM
Its easy but fairly time consuming. Get yourself a service manual, a fork seal driver, and a oil level gauge and you should be set. Be careful when putting you new seals on because there are some sharp metal eadges you have to slide the seals past. You can cut the seals while trying to get them past the sharp edge and they won't seal. A trick is to put some oil on a piece of plastic warp and put it over the end of the fork before sliding the seal on. I used to have lots of problems with my KX going through fork seals. Dennis kirk seals some that are guaranteed not to leak and if they do you can get a new pair for free.
Old 12-05-2003, 06:15 PM
MotoMan's Avatar
Floppy
Last Online: Today 08:27 PM
If they just started leaking and it is running out cowboy's trick should work for you. You can also use a feeler gauge to do it as well.
Old 12-07-2003, 09:11 PM
brokenbone's Avatar
Thanks for the feedback. I'll try the card trick and if that don't work i'll try to fix it myself.
Old 12-14-2003, 09:32 PM
Last Online: 11-01-2006 03:04 AM
I just replaced the fork seals on my 1995 Husky, it wasn't that hard. I figured I could always take the forks in if I couldn't do it. I made a seal driver out of a PVC pipe coupling that was about the same size as the bottom part of the fork.
Here is a link that helped me a lot.....
You can skip a lot of the steps that remove the valves as you are just seperating the forks and changing the seals.
Hope this helps and good luck,
Replay
Old 12-14-2003, 09:52 PM
paul reed's Avatar
pro class pimp
Last Online: 05-19-2009 07:59 PM
that cowboy sure knows his stuff!....maybe i should start readin dirt bike mags instead of big tit muff diver mags....besides,i`m gettin arm pump and somehow the pages are all gettin stuck together...dirtbikers don`t need viagra
Similar Threads for: Help! my forks are leaking.
Are cr125 forks the same as cr250 forks? Beans 2-Stroke Motorcycles - Honda 1 04-14-2009 12:09 AM
Front forks leaking AdrenalinJunky 2-Stroke Motorcycles - Kawasaki 1 05-20-2008 09:02 PM
forks are leaking? tonymtona 4-Stroke Motorcycles - Yamaha 9 04-20-2008 08:56 AM
Forks leaking a little Shoei_391 4-Stroke Motorcycles - Yamaha 2 01-12-2008 03:35 PM
NEW FORKS LEAKING OIL???? mxmama393 Mini Motorcycle Riders 9 04-16-2007 11:46 AM
