Fuel Consumption?This is a discussion on Fuel Consumption? within the 2-Stroke Motorcycles - Kawasaki forum, part of the 2-Stroke Motorcycle Forums category; Hi Guys I need some advice on this topic. I just bought my KX125 and took it out for a ... |
| Hi Guys I need some advice on this topic. I just bought my KX125 and took it out for a couple of hours of riding on Sunday. I was not sure how long I could ride before the tank was close to empty and it seemed to have gone through about 3/4 tank in about 8-9 miles of trail riding. My bike is completely stock with the exception of the previous owner going up on the main jet 1 size. He told me that when he rode it he was usually going at high speeds and so he changed the jetting in order to dump a little more fuel into the cylinder. He also ran a mix ratio of 25:1 and our elevation is about 5000ft. With the jetting change, would this cause me to burn fuel at a faster rate than normal when i was not riding near full speed? I would also like to know if the 25:1 ratio is too much oil in a 5 gallon can? After riding I noticed the oil spooge leaking from the tail pipe, I would assume this is normal right? Thanks, Chris. |
| A little oil coming out of the silencer is normal, but if it's running out, it's probably a result of rich jetting or the 25:1 mix ratio. I use 32:1 in my CR125, some people run 40:1, 50:1. At 5,000 ft stock jetting is normally too rich. Was the previous owner also at 5,000 ft? |
| Yes he was at the same elevation. The oil out the tail pipe really is not running out but more like after I stopped riding then it leaked out enough to make a few drips of black oil on my garage floor. Maybe the mixture is too rich, guess I'll pull the plug to look at it. The performance was really good but I was just concerned with how fast the bike burned up 2 gallons of fuel. |
| I'll second that 25:1, that's nutz. Go 40:1 and keep an eye on that plug color. Your getting way to much spooge= too rich. |
| Go with a good oil too, something like Amsoil |
| Fuel | mike1100 | 2-Stroke Motorcycles - Suzuki | 1 | 02-26-2007 08:44 AM |
| How to Tip - 4 stroke fuel screw secretsÊ HOW TO TIP - 4 STROKE FUEL SCREW SECRETS | Satch0922 | 4-Stroke Motorcycle Knowledge Base | 4 | 02-14-2005 11:04 AM |
| 45r fuel | honda_stud | 2-Stroke Motorcycles - General Discussion | 3 | 08-13-2004 08:14 PM |
| 426 Oil Consumption?!??! | ScottYZF426FLA | 4-Stroke Motorcycles - Yamaha | 7 | 01-04-2004 07:36 PM |
| Oil consumption | cjs_moto | 4-Stroke Motorcycles - Honda | 17 | 11-26-2003 10:43 PM |
