99' KX125 ""sneezing""/""Hic-up"" noise...This is a discussion on 99' KX125 ""sneezing""/""Hic-up"" noise... within the 2-Stroke Motorcycles - Kawasaki forum, part of the 2-Stroke Motorcycle Forums category; When i tried to get my 99 kx125 going the other day after i fouled a spark plug it wouldnt ... |
| When i tried to get my 99 kx125 going the other day after i fouled a spark plug it wouldnt start... I called my friend over to see what was the matter with it. (hes good with 2-strokes and engine stuff)... he said i probably pushed it to hard and burned up my piston rings... i dont know though... but whenever i try and start it up: #1 it has no compression, (i can push the kick down with 1 finger); #2 after like 3 or 4 kicks with the choke on it hicups, or almost like a sneeze; and #3 it backfires....... I need someone to explain to me the backfiring and "sneezing" noise.. My dad and friends have tried to explain it to me but they all tell me different things... I just need a GOOD explination, and help with this... |
| Trust you father! It has never steared me in the wrong direction! -Pintlar- |
| IF you have no compression id say you need a top end. As for the other noises you would be surprised at what could cause that but i think you will fix most of that by getting the top end fixed. I have found many reasons that a bike hicups or backfires you may have a problem with your timing or firing system since it fouled the spark plug and if the timing is off that will cause a backfire. You should probably check the piston first if it is that easy to turn over. Good luck |
| Theres no way of knowing until you tear it down. Take it apart and check the damage. |
| My lil 80 expert did the same thing. I actually broke a boyseen dual stage reed. So i bought new ones and a new vertex ring and wala she fired up in one kick. Check your reeds. |
| my little yamaha currently dose they same thing, what im going to do is replace the rings and if that dosent help ill end up rebuilding the hole top end. |
| top end.. |
| Jeremy Mcgrath 16" "BMX" bicycle | Huffa | General Discussion | 5 | 03-30-2009 03:11 PM |
| Josh Strout AKA "Cody's Dad" Going "OLD SCHOOL" at the GMB | Satch0922 | GMB V | 11 | 10-10-2006 08:50 PM |
| ""n e riders live in europe"" | Hondaboy007 | General Discussion | 8 | 09-09-2006 02:15 PM |
| CR250 "A" clyinder vs "B" cylinder. How to indentify. | Mike[socal] | 2-Stroke Motorcycles - Honda | 6 | 03-10-2005 10:02 AM |
