All Things Moto! Web Forums
76 kd 125 transmission problems
This is a discussion on 76 kd 125 transmission problems within the 2-Stroke Motorcycles - Kawasaki forum, part of the 2-Stroke Motorcycle Forums category; i have a 76 kd 125 that you can shift into first and second easy. but then it is hard ...
Old 06-10-2009, 02:57 PM
Last Online: 08-22-2009 10:11 PM
Default 76 kd 125 transmission problems
i have a 76 kd 125 that you can shift into first and second easy. but then it is hard to get it into third but if you shift up and down and work at it you can get it into all of the gears. does anybody know what might be wrong. i havent taken anything apart yet so i don't know what everything looks like.
Old 06-10-2009, 03:06 PM
MXtras's Avatar
Manufacturer
Bent shift forks or worn and notched shift spool would be my guess. I have never been inside a bike of this vintage, though so these are simply guesses.
Scott
Old 07-03-2009, 03:13 PM
ok i have another question about this bike and transmission. the bike sat for probly 10 years and then sombody got it running and the transmission was run dry for a little bit i guess but could it not shift just because of there being no oil in there or did not having any oil in it wreck everything. i know its a stupid thing to happen but i just got thinking about an automatic car transmission somtimes if they get low they stop shifting right and i just wondered if the same thing could happen
thanks
Old 07-03-2009, 06:52 PM
Last Online: 11-02-2009 04:01 PM
Default transmission with no oil
The oil in a 2-stroke motorcycle engine is for lubrication only. The fluid is not used in a hydrolic fassion to change the gears in any way.
The only way to figure out what is going on is to split the case. It's not a big deal but you should get the proper tools (case splitter) to do the job correctly. Once inside you will most likely see the problem easily. It should be easy to fix also (most cases are). And while in there, might as well change the bearings and seals!
good luck and let us know the deal (take pictures and post).
nola_fiddy
Old 07-03-2009, 11:16 PM
alright thanks i just wasnt sure and thinking through any ideas that come up since i have never had any kind of problems like this before and i have always had hondas but i had this bike here and it is almost running and i figured i might get it going without to much trouble and ride it if my 250r has a problem
Similar Threads for: 76 kd 125 transmission problems
2008 rmz transmission problems gixxerl7 4-Stroke Motorcycles - Suzuki 1 05-02-2008 12:07 PM
05 yz450f Transmission problems Piche 4-Stroke Motorcycles - Yamaha 8 07-14-2006 01:04 PM
Clutch/Trans problems after switching from 10w-40 to transmission specific MTL 75wt. thehardway 2-Stroke Motorcycles - General Discussion 8 08-13-2004 02:24 PM
Transmission Oil Dirtrydar General Discussion 9 09-16-2003 12:00 PM
YZ450F transmission problems??? Woody_YZF 4-Stroke Motorcycles - Yamaha 8 07-25-2003 07:34 AM
