Old 04-04-2019, 06:38 AM
2smokerman's Avatar
Last Online: 04-21-2019 09:59 AM
Angry 1998 Kx100.. Odd problem
Bought a 1998 kx100... The man pulled up with it and fired it right up. We got
It off the truck I hopped on and fired it right up and took off for about 5 minutes to see if it went through all the gears and rode good. No problems that I could tell. I ended up parking it and going back to work after he left. About 20 minutes later I went out to kick it over and it wouldnít start. Took the plug out, was fouled so I assumed I didnít let it warm up good before taking off. Replaced the plug and nothing. I can bump start it for about 4 seconds it will give a really bogged idle then when I hit the gas it dies. Iím assuming one of the jets is clogged but at the same time Iím confused as to why it started up fine then as soon as he leaves havenít been able to ride it since.
Old 04-04-2019, 04:56 PM
gusco's Avatar
Last Online: Yesterday 09:51 PM
Maybe the carb is overflowing. So if the PO knew that, he may have left the petcock off until he was ready to start it. If you left it parked with the petcock on, that may have allowed it to flood while it was parked. A clogged jet will cause a lean condition, not a rich condition (fouled plug). I'd pull the carb and check for the condition of the needle/seat.
Old 04-05-2019, 04:45 PM
2smokerman's Avatar
Thanks for the help I didnt think about that. I ended up grabbing a needle jet and needle after work today the carb is spotless but still same thing except now Iv noticed a noise coming from the bottom end sort of like a spinning noise when I kick not the same winding noise when a bike starts but like a dry spinning noise. Kind of strange.. crank kit?
Old 04-05-2019, 10:50 PM
bjunior's Avatar
novice
Last Online: Yesterday 09:47 PM
Hi check the basics is it getting a spark 2- is the plug wet from gas or oil?
Old 04-08-2019, 08:43 AM
Last Online: 06-13-2019 11:53 AM
Check the air filter, and if it is clean take a look at the reeds.
"Spinning noise" is a tough thing to diagnose over the internet, I'd start by making sure it has oil in it, and if it does go ahead and drain/refill just so you know what you're dealing with. If you still hear the sound I'd start by checking the clutch components for wear then dig deeper as necessary until you find the problem.
Old 04-16-2019, 06:18 PM
2smokerman's Avatar
Cleaned the air filter it wasn’t bad, clutch looks brand spanking new.. oil was good ended up taking the cover off to the flywheel and the nut that goes on the crank fell out! The threads are smashed unfortunately. Flywheel slid right off the woodruff key was stuck inside of it.. I’m pretty sure the guy got the nut on as tight as he could but only could get it about halfway, enough to get one quick test ride in then pop went the nut smashing the top 3 threads
Similar Threads for: 1998 Kx100.. Odd problem
1998 YZ125 power problem. MrZakk510 2-Stroke Dirt Bikes - Yamaha 6 05-24-2015 09:51 PM
kx100 problem tacoguy 2-Stroke Dirt Bikes - Kawasaki 2 07-05-2013 10:30 PM
1998 Yamaha Big Bear 350 Reverse Problem Hayseed ATV/UTV - Yamaha 0 09-13-2010 01:20 PM
1998 cr250 fork problem 08raptor700 2-Stroke Dirt Bikes - Honda 13 08-12-2010 01:41 PM
1998 cr125r problem starting.... 1998cr125r 2-Stroke Dirt Bikes - Honda 19 03-25-2010 08:01 AM
