01 kx250 starts but stuck wide open
This is a discussion on 01 kx250 starts but stuck wide open within the 2-Stroke Motorcycles - Kawasaki forum, part of the 2-Stroke Motorcycle Forums category; well guys i just got done doing a rebuild and i got every thing together but when i first started ...
Old 07-01-2007, 01:52 PM
Last Online: 05-19-2008 09:41 AM
Default 01 kx250 starts but stuck wide open
well guys i just got done doing a rebuild and i got every thing together but when i first started it the throttle was stuck wide open so i hit the kill switch...i was thinking it was the slide so i took it apart and cleaned everything.jets/floats/needle and slide so i put it all back together tried to crank it it but it only starts when the choke is pulled on and it did the exact same thing so i tried to crank it with no choke and it wont do nothing...so what else can i try to get this thing to idle right so i can do the heat cycles..any help would be helpfull
Old 07-02-2007, 03:04 PM
Default Re: 01 kx250 starts but stuck wide open
well i figure it out it was sucking air between the reed cags and the back of the block..never figured that a small air leak would cause a bike to run wide open...
Old 07-02-2007, 04:02 PM
Last Online: 07-15-2008 10:23 AM
Good job. Even a pin hole will do that.
Old 07-02-2007, 05:02 PM
ok now i have another problem i got it to idle but their is no smoke coming out of the exhaust..i know its not the mixture of the gas b/c b4 i did the top end i had about 1/4 tank left from a previous ride...so what else could it be i open to any suggestions...
Old 07-03-2007, 07:55 AM
No smoke doesn't really mean anything. My 250 doesn't smoke after it's warmed up. You may want to empty the fuel left in the tank and mix up some fresh fuel.
Old 07-03-2007, 11:45 AM
no i ment when i first cranked it up there was no smooke coming from the exhaust and for thr lil time it was running the pipe started to get really hot...i have to take the jug back off b/c i have a small water leak right under the exhaust port......
Old 07-03-2007, 12:25 PM
When you take it back apart, make sure all the surfaces where the gaskets are are super clean. Use a razor blade and scrape in a dragging motion to clean them.
Good Luck and TAKE YOUR TIME!
Similar Threads for: 01 kx250 starts but stuck wide open
wide ratio kit tchui Wanted Items 2 07-25-2008 03:16 PM
2001 kx 125 bogs when cracking it wide open sinisterkx 2-Stroke Motorcycles - Kawasaki 6 10-24-2007 03:17 PM
Anybody Who Thinks Desert Racing is Wide Open Ride Fast Watch This Dirtbikindad393 Photo & Video 15 03-28-2007 12:00 AM
Wide open Austin225 General Discussion 2 05-14-2004 04:33 PM
"Wide Open" By: Jeremy McGrath brcrk General Discussion 27 02-18-2004 10:59 PM
