Old 07-15-2004, 02:38 PM
Cr125zrule's Avatar
Last Online: 01-17-2009 06:07 AM
Default wont start just backfires..wont pick up or nuthin
hey guys,
just put a new ring in my cr.....it had good compression but has lost it after the first start..but the ring is not broke.......i rode it around ....then to get it started i had to result to bumping it and it would go great wheelie in most gears.....now it wont even bump u will push it and it will just go bang..(backfire) any help would be great ..thanks guys/gals
Old 07-15-2004, 02:47 PM
YZGreg's Avatar
Last Online: 04-07-2006 11:32 PM
Default Re: wont start just backfires..wont pick up or nuthin
It sure sounds like you broke the ring. Did you just put a new ring in or was it sitting a while? It seems like all the power is going past the ring and out the pipe in a backfire. You did lube the cylinder/piston real good didn't you? If not it may have scored the cylinder. Its kind of hard to know what the prob is without more info like how much compression it's really got in PSI, it might feel like enough even with a broken ring. Other than that it could be a fouled plug.
Old 07-15-2004, 02:49 PM
drman's Avatar
Almost sounds as if you sheared a flywheel key...
Old 07-15-2004, 02:52 PM
Cr125zrule's Avatar
fly wheel key wud that explain when i pull away it did not pull away smooth the engine had a judjer to it.....wat do u guys rekomend i do...i lubed the barrol with 2 caps of 2 stroke...anythin else...thanks
Old 07-15-2004, 03:47 PM
YZGreg's Avatar
The only way the flywheel key could get broken would be if the nut was loose, but it wouldn't run at all then. How do you know the ring isn't broken? Did you do a compression test? Maybe you put the piston in backwards? I don't know what else it could be if it was fine before you re-ringed it.
Old 07-15-2004, 07:17 PM
CR Chick's Avatar
Last Online: 11-18-2006 03:14 PM
check the spark plug gap. that might be the problem.
Old 07-16-2004, 01:06 AM
Cr125zrule's Avatar
yeah it was fine before i reringed it....i dont think it strts now......there isnt much compression but its a new ring..how else wud i loose compression
Old 07-16-2004, 01:15 AM
Aus_Rider_22's Avatar
Last Online: 04-20-2020 08:05 PM
I put new ring and piston in my bike and after 15 mins of riding it lost all compression and died. The ring caught the ehaust port and scored the bore and re-plating was needed!
Hope it's not llike that for you! Good luck!
Old 07-16-2004, 01:21 AM
Crazy's Avatar
Last Online: 01-19-2014 09:57 PM
Thats the same thing my friends did we couldnt get it started just a backfire here and there. It ended up being that the ring on one side of the piston was messed up and the compression dropped to about 20psi.
Old 07-16-2004, 09:52 AM
Cr125zrule's Avatar
the ring has had less three hours use on it tho
Similar Threads for: wont start just backfires..wont pick up or nuthin
04 CR 125 WONT START RHS34AS 2-Stroke Dirt Bikes - Honda 8 03-30-2012 02:09 PM
97 yz wont start jsportillo 2-Stroke Dirt Bikes - Yamaha 2 11-19-2007 06:12 PM
Why wont start?? VET393 4-Stroke Dirt Bikes - Honda 5 10-28-2007 04:48 PM
Wont start while hot Shoei_391 General Discussion 26 05-28-2007 08:47 AM
xt 550 wont start Cyb3r_GoD 4-Stroke Dirt Bikes - Yamaha 10 02-18-2004 05:43 AM
